LS3 timing chain tensioners: differences?
Not interested in an LS2 damper vs. LS3 tensioner debate in this thread. Just curious if there are variants of the LS3 tensioner that I should be aware of. I read rumors that there was a change in tensioners in '09, but I don't know what the change was. I also can't find a parts diagram online anywhere showing the GM part number for the tensioner.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Sorry Clint, you just can't keep people from repeating Internet Gossip.. Single bolt cam gears, like the VVT system, have to use the tensioner.
What I really want to know is if there is a new, improved, or revised design tensioner available - either with new materials, new design, or something different that might make it more reliable than the original LS3 tensioner. I am very curious if the -407 PN tensioner uses a different kind of plastic, different heat treat on the leaf spring, or other improvement.
The new LT1 looks like it has a similar tensioner design. Maybe it will be better and maybe it will be interchangeable with the gen III/IV.
As far as the Gen V goes, I can see it going either way. In many ways it is pretty obvious that they simply expanded on the successful Gen IV design, but they did it in a fairly serious and meaningful manner and I can see where there would be benefits to improving the tensioner design.
The solution is a Cloyes Billet set, these feature 'oversized' cam & crank gears that eliminate the slack found in stock chains and other aftermarket sets.
Adding an LS2 damper in this case is advisable as it prevents the chain whipping back under rapid deceleration - the main cause of chain failure.
I do like the easy cam degree adjustment!
I know Cloyes is highly regarded for SBC and other parts; and a Tier 1 auto supplier.
IIRC, Cloyes makes an SBC cam gear cover with a removable plate for accessing the adjustable cam gear bolts. That would be cool for LS engines too.
In the VVT world, we don't have many options. I am doing the factory sprockets & spring tensioner with the "C5.R" chain.
