Difference in cnc ported heads vs non cnc
Horrible cam for these heads. Been there-done that.
degrees more cam timing on the exhaust side. The CNC versions tend to get
that ratio in the 70-75 % in which case you wouldn't need nearly as much
split. Texas Speed, EPS, or Tick can get you dialed in on the right numbers
for what you want the engine to behave like.
I thought that was the cam you where referring to.
In our cam only LS3 I went with 231 239 .617 .624 113, it's a very "torque" cam with great mid range.
http://www.engpwrsys.com/index.php?act=viewCat&catId=19
Just my $.03 but do whatever...
