TrickFlow GENX 255cc LS3 Heads
Old Jul 7, 2013 | 08:45 PM
  #61
oakley6575's Avatar
Originally Posted by ws6guy27
Cant wait get my set from brian going be the shitz
What is Tooley doing to them?
Old Jul 9, 2013 | 05:36 AM
  #62
litle88's Avatar
Originally Posted by CETAWS6
I'm very interested to see how these would do on my car...
Lol with ya CETA! I'm a huge fan of TFS.
Old Jul 9, 2013 | 01:54 PM
  #63
oakley6575's Avatar
If someone would pull the trigger on my stock LS3 heads/intake in the classifieds, I would order the TFS right away.
Old Jul 9, 2013 | 09:04 PM
  #64
CETAWS6's Avatar
I will try to get these soon. I'm really thinking about it real bad.
Old Jul 10, 2013 | 05:05 AM
  #65
ws6guy27's Avatar
Putting his spring kit in them. Light valves. And mill to 65cc. For my 13.1 compression. Still waitong on valves tho. ;/
Old Jul 10, 2013 | 01:28 PM
  #66
oakley6575's Avatar
Damn I thought the valves were supposed to be ready last month. Should be **** when you get them back from him
Old Jul 10, 2013 | 02:22 PM
  #67
ws6guy27's Avatar
Yeah should be. Cant wait see how thr setup going run
Old Jul 13, 2013 | 02:23 PM
  #68
weldermike27408's Avatar
Subscribed to this thread !!! I found the part number for these as a bare head ... Does anyone know if Trick Flow will sell a bare as-cast version of the TFS LS3 heads ???
My TEA TFS 235 head swap got de-railed by a clutch/trans issue...had to sell them but it worked out good...wound up going to guy who had the bottom end they were spec'd for anyway...I'm gonna resarch TFS LS3 options now...had been looking into having a set of Warhawk LS7 heads done for my bore (med bore) but not anymore
Old Jul 13, 2013 | 02:28 PM
  #69
Originally Posted by Brian Tooley
The GM 4.900" stock length LS3 hollow stem valves are 89 grams.
The TFS heads have LS7 length valves, so the GM LS3 valves won't work. However, GM LS7 titanium valves with the head diameter turned down will work.
TEA will have an option for hollow stem intake valves for these heads, I'm sure AI will be able to supply those as well.
Manley has a hollow stem LS7 intake valve(11688H-8)110g...those could be turned down to work as well correct??Solid Exhaust(11679-8)103g too??
Old Jul 13, 2013 | 03:10 PM
  #70
Camper's Avatar
zeke, I almost grabbed these for my build. But I want to see what they do first. It's these or the ls7 small bores when I pull the trigger
Old Jul 13, 2013 | 03:42 PM
  #71
Brian Tooley Racing's Avatar
Yes, that's correct.
The REV hollow stem valves are supposed to be closer to 100 grams, but I haven't received verification of that, nor have I been able to weigh them myself.
The REV valves came in but the back cut or 45 width's were incorrect. They're going to regrind them and flow check them to see if they'll work.
Old Jul 13, 2013 | 09:48 PM
  #72
nitrousking's Avatar
$600 for 8 intake valves=smoking crack
Old Jul 19, 2013 | 07:35 PM
  #73
CETAWS6's Avatar
Does anyone know is there "as cast" version of these heads?
Old Jul 21, 2013 | 10:32 PM
  #74
lil john's Avatar
Oh when I first got the heads before I sold them I called TEA and asked if they did a NOS exhaust port...it was in the works should be done by now you guy should look into it.
Old Jul 22, 2013 | 04:22 PM
  #75
litle88's Avatar
Anyone get on the dyno with these heads?
Old Jul 22, 2013 | 04:29 PM
  #76
wesam's Avatar
I will post dyno results for those heads with 403CI next week
Old Jul 22, 2013 | 10:18 PM
  #77
litle88's Avatar
Cool! Thanks
Old Jul 22, 2013 | 10:19 PM
  #78
litle88's Avatar
Either one Dave! They show lots of potential!
Old Jul 22, 2013 | 11:17 PM
  #79
xdanny510x's Avatar
How would these heads compare to texas speed prc 260cc ls3 heads
Old Jul 22, 2013 | 11:36 PM
  #80
lil john's Avatar
All of these heads LS7-3 will be 5 to 20 hp difference
