Tapping ls3 for knock sensors
Old May 25, 2013 | 10:23 PM
secondss's Avatar
Default Tapping ls3 for knock sensors
I'm in the process of doing an ls3 swap and have a few quick questions. I know I have to move the knock sensors to the sides and drill and tap holes...but how deep should I go and where should I drill?
Also the ls1 valve covers won't fit, is it best to by ls3 covers or is it safe to gut the ls1's.
Old May 27, 2013 | 06:54 PM
HSV-GTS-300's Avatar
Drill the 2 existing 8mm threaded knock sensor bosses out to the tapping size for a 10mm thread. You only drill to the depth of the 10mm thread. They are blind holes.
Old May 28, 2013 | 01:52 PM
SNLPerformance's Avatar
OP,
Here you go!
http://www.ls1gto.com/forums/showthread.php?t=443140
Old May 28, 2013 | 04:18 PM
VTC_WS6's Avatar
http://www.racetronix.biz/itemdesc.a...1-KSRH&eq=&Tp=
Just another option for you.
Old Sep 8, 2013 | 11:50 PM
AwesomeChump's Avatar
Hey guys I know this thread is a few months old, but what size drill bit and tap is needed for this? TIA
Old Sep 14, 2013 | 02:28 PM
jegten's Avatar
Drill with 8.5mm bit, then tap with M10 x 1.5 hand tap.
Old Sep 16, 2013 | 10:07 AM
I've looked all over for a drill bit that size with no luck but I did find this one http://m.summitracing.com/parts/wmr-w8619. Would that work?
Old Sep 16, 2013 | 06:58 PM
jegten's Avatar
it should since they are matching them both.
i was going to mention that when i went to get the set for the second time, i went to NAPA and the kit they sold me had a standard drill bit, x/32. i just don't remember the x value.
yeah, if they are offering both as a kit, you should be good to go.
Old Sep 16, 2013 | 08:44 PM
S10xGN's Avatar
Metric 10mm x 1.5 calls for a 8.5mm drill bit which is 0.335", closest US drill sizes are:
  • 21/64 = 0.328"
  • Q = 0.332"
  • R = 0.339"
  • 11/32 = 0.344"
HTH,
Old Sep 16, 2013 | 09:47 PM
Thanks for all the help guys! I'm going to go ahead and order the drill bit and tap from summit.
Old Sep 17, 2013 | 09:51 AM
studderin's Avatar
It might be a nice tap and drill, But I would spend the extra 10-20$ over the cheap $6 summit drill and tap set, and get a real quality drill and tap. I nice drill and tap are almost priceless over using ones that are cheap and suck when you look at what your doing with it, and whats 5-$20 more whats your paying for. Its your time if it the hole dosn't drill nicem and the tap dosn't cut nice and clean, or gets stuck and breaks. Your doing this on a LS3 motor not a headlight bracket for your snow blower.
Old Sep 17, 2013 | 09:56 AM
studderin's Avatar
go to you local tool house/ suppy store. you don't have to have that shipped even.
Old Sep 17, 2013 | 12:50 PM
Damn thats's a good point, I didn't even think of that. Off to the parts store I go! Thanks for the advice man!
Old Sep 17, 2013 | 01:50 PM
68 SS's Avatar
Just remember start the tap a few turns then bck it out then go in a few more turns use plenty of oil and you will be fine just dont get the tap in a bind and try to force it.
