Looking for more out of my LS3, ideas?
Motor is a hand built 377ci LS3. K1 rods, ARP2000 rod bolts, Clevite rod bearings, ACL main bearings, SRP 4032 pistons (5cc, .01 above deck), & 222/230 112+2 cam by PatG. My top end is FastToys Lid (I think it's an 85mm) > TSP 100mm MAF w/ screen > Nick Williams 92mm TB > stock LS3 intake > stock LS3 heads milled .020 with stock hardware except PAC 1518 springs. Only street tuned w/ mail order tune from Frost at this time. Static compression right around 10.8, I think DCR is around 8.2. Not interested in larger displacement, but I'm open to higher compression so long as it's compatible with 92-94 octane fuel.
Fuel system is stock LS3 injectors, Racetronix harness kit & Racetronix 255lph Walbro pump.
Exhaust is ARH 1.75" headers > ARH 3" catted Y-pipe > SLP dual-dual (with cutout). I don't like the sound of the exhaust without cat's.
Drivetrain is a T56 with basic upgrades, LS7 clutch with Fidanza 13.5lb flywheel, OEM AL driveshaft, OEM 10-bolt with 3.73 gears. I have considered going back to a 3.42 final drive if I could get the tip-in bucking resolved.
It's a daily driver which needs to remain reliable and low maintenance, don't want to worry about checking/replacing valvesprings, would like better fuel economy at cruise, max average torque between say 2500 & 6000. No drag racing, spirited street cruising, perhaps I'll get back into autocross or someday try my hand at a HPDE but I worry about the poor LS3 oil drain back for those activities.
I feel I lost some of the snappiness in the throttle when I switched from the LS1 to the LS3, and I've read that is a result of going from cathedral to wide rectangular intake ports. But I've also read that the there aren't any real gains (except a much lighter wallet) to be had with the Fast cathedral intake on a stock displacement LS3. Not interested in nitrous.
I was considering a BER or PeakSpeedShop ported LS3 intake and maybe better heads and a matched cam, but are there any other changes I could consider to raise my area under the curve in that RPM range and help with the other desires also?
Last edited by JimMueller; Sep 15, 2014 at 02:07 PM. Reason: Cam LSA is 112 (not 110), heads milled .020 (not .030)
Would there be such a thing as a complete boost solution (which includes all additional supporting mods) that meets my goals but would be maybe closer to $5K?
A&A also sometimes sell a "newsed" kit. A rebuilt blower with all new everything else. Those are usually around $4500 if they have some.
Rectangular:
TFS GenX 255, 255cc (12 degree)
Mast 510-202 (LS3 12 Degree 4.000" - 4.070" Medium Bore CNC), 255cc
PRC 199-265LS7SB LS3 (LS7x 265cc CNC Small Bore Heads), 250,255,260c
SDPC LS3 CNC Ported
Cathedral:
AFR 215/230/245cc Mongoose
Mast 215/245cc
PRC 237/247cc
TFS 235 - scratch that, needs min bore of 4.125
Not getting my questions answered by PRC nor TFS.
Motor is a hand built 377ci LS3. K1 rods, ARP2000 rod bolts, Clevite rod bearings, ACL main bearings, SRP 4032 pistons (5cc, .01 above deck), & 222/230 110+2 cam by PatG. My top end is FastToys Lid (I think it's an 85mm) > TSP 100mm MAF w/ screen > Nick Williams 92mm TB > stock LS3 intake > stock LS3 heads milled .030 with stock hardware except PAC 1518 springs. Only street tuned w/ mail order tune from Frost at this time. Static compression right around 10.8, I think DCR is around 8.2. Not interested in larger displacement, but I'm open to higher compression so long as it's compatible with 92-94 octane fuel.
I'd say mill the heads some more to get around 11.5:1 compression.
Im running a 220/230 at .050, 108+4 cam in my stock GM crate LS3 and am right at 228 lbs of cranking compression. It likes pump 93 ok at 34* max timing, but I wouldn't want to push it any farther than that.
So I guess I'm interested in shifting my curve straight up as much as I can with the modified (not to be confused with ported) LS3 manifold, heads, valvetrain (higher lift rockers?) and matching cam. If I can get a bit better fuel economy below 2000 by shifting the curve to the right a bit I'd be all right with that.
Not sure how much I can mill before worrying about PTVC. Without a cam change, dropping to a 60cc chamber would put me at 11.5 SCR and 9.0 DCR with my current AIVC of 65.5. I'd need an AIVC of 70* or later to keep DCR around 8.7 or less.
