Quench too tight?
I ran a 496 BBC at .031 with shifts at 6500 rpm and never had contact. I pulled the heads at 20000 miles for a refresh and looked great. Pistons will stay cleaner.
When figuring quench with dished pistons. How do you measure that?
Example. Ly6 stock block. I think the stock pistons measure -6cc.
Sorry not trying to hijack, more like piggy back.
Allso to consider with tight quench is piston rock and piston material Cast pistons run tight clerances so they rock less and then grow very little,some pistons have bad skirt desings to be run tight
Iron block with cast oem pistons dose not grow much,with Kents .036" quench is an accurate number less then waht you are running and he probably pics up good power by doing that
