Crank slow to spin after installation
To give you an idea, I could turn it with my index finger on the side of a bob weight, but I struggled to turn it when using my pinky finger. Hanging some weight off the side, I’d estimate it at around 3-4 lb-ft of resistance. It’s nothing ridiculous at all, but it certainly doesn’t want to ‘coast’ as I saw one person put.
It’s been awhile since I disassembled the engine, but I thought I remember the crank spinning quite easily before. I was thinking/hoping it has to do with the fact that disassembly was on motor oil at 70*F whereas now it’s on assembly lube at 30*F.
Motor oil viscosity at 70*F would be about 0.08 Pa-s.
Assembly lube viscosity at 30*F appears to be around 14 Pa-s (similar to honey). This is about a 150x increase in viscosity and thus drag.
I would think this could be causing the difference, but I was hoping to hear from someone who has done this a few times to be sure. Will cold weather and assembly lube cause the crank to resist being spun? And yes, I checked the bearing clearances with a micrometer and dial bore gauge. I also ‘aligned’ the #3 bearing.
Appreciate any input.
Taking the inner bolts to 80* and the outer bolts to 51* took about the limit of my strength on the breaker bar I had, so I think it's unlikely I went over the spec by and significant margin on any of the bolts.
I did find two other people on other websites who had similar issues with the same green Sealed Power assembly lube I used. That it was so sticky, it pulled the bearings out with the crank when they went to pull the crank and re-try assembly with motor oil. But without having personally experienced this, I'm probably to the point of needing to waste a few hours re-doing it just to convince myself.
I really don't like to assemble with assembly lube for this reason though. If there is a problem, like some dirt or a nick in the bearing, it would cause a slight resistance that you couldn't really feel with assembly lube. I prefer to assembly with oil, preferably a "break in" oil. The only time I use assembly lube is if I knew the engine would be sitting for a long time before being used.
