Morel link bar lifter for LSX block?
Old Mar 25, 2014 | 11:03 AM
6togo's Avatar
Default Morel link bar lifter for LSX block?
Can anyone confirm what part # will work with a Lsx block I been told you need the 5274's that have the V in the bar but those are really for warhawk blocks that have a head stud next to the lifters which I don't think are needed on a Lsx block so will std LS 5206 versions work without issue?
Old Mar 25, 2014 | 05:23 PM
JS01's Avatar
Either will work in the LSX block.
Old Mar 25, 2014 | 07:56 PM
6togo's Avatar
Are you running either in a LSX?
Old Mar 25, 2014 | 08:19 PM
Briou's Avatar
I have had this discussion with Martin at Tick....Either will work...I will be running the ones with the V in the link bar in my LS3 short block
Old Mar 25, 2014 | 08:21 PM
Darkman's Avatar
https://ls1tech.com/forums/16808748-post23.html
Old Mar 25, 2014 | 09:23 PM
6togo's Avatar
I know what that says it's my thread but i have seen standard link bars in the LSX blocks i dont know why they recommend warhawk versions when that setup is clearly different!
Old Mar 25, 2014 | 10:18 PM
Briou's Avatar
Someone can correct me if I am wrong but I believe that the v link bar lifters are the replacement for the straight bar, as they will work in warhawk blocks as well as the non warhawk blocks....at least thats what I've been told
Old Mar 25, 2014 | 10:46 PM
6togo's Avatar
I heard a rumor they were doing away with the 5206's for that reason the 5274's will work in a std. LS also so they have no reason to produce the other's.
