75k different pushrod length side to side??
I am running morel link bars with stock ls rockers and pedals. I came up with 7.325 pushrods.....that us 75k less than the 7.40 ones on the drivers side.
Questions:
1. Am I doing it wrong. I set to zero lash. Then I look for 1.5 turns more
2. What would cause the difference? Milled different? Valve height different?
Thanks
Edit: If the lifters are Morel 5206, the preload window is from 0.030" to 0.050." It is often necessary to order custom length pushrods to accommodate the narrow window.
http://johncalliesinc.com/pdf/Adjust...licLifters.pdf
