New LSX 454 build
Old Dec 6, 2015 | 10:22 AM
  #61
SSSTANG#1's Avatar
Siemens-Deka injectors work on the Mast intake. Mine are 80 lb/hr.
Old Dec 6, 2015 | 10:47 AM
  #62
SSSTANG#1's Avatar
Btw, I love the cannon plug idea.
Old Dec 6, 2015 | 04:39 PM
  #63
LSX67RS/SS's Avatar
thx Stang.....
Question did those injectors have o-rings on the end and if so how do you assure they don't "slip" down as the intake heats up and the press fit loosens up or this just isn't going to happen?
Old Dec 6, 2015 | 06:39 PM
  #64
SSSTANG#1's Avatar
I lubed the o-rings and stuck them in. I don't remember being concerned at all that the o-rings would come off.
Old Dec 6, 2015 | 07:43 PM
  #65
SSSTANG#1's Avatar
I found this pic with a view of the injector boss. As you can see, there is a groove for the o-ring.
Here is the only pic I have of an injector and you can barely see the o-ring to the right.
Old Dec 6, 2015 | 08:10 PM
  #66
BOLO's Avatar
I have the MAST LS7 4500 Efi intake as well. I too, run Siemens injectors, same as SSSTANG but 60#'s
Old Dec 6, 2015 | 09:40 PM
  #67
LSX67RS/SS's Avatar
thx guys, just took a look and verified there's a relief cut as yours for the o-ring. I'm going to say good to go without the little plastic cups on the ends. Although i am going to call injector vendor and ask about the differences in spray pattern and atomization with and without the caps.....
I'm also considering to re-dyno...over the holidays, i'd like to know if that caps made a difference at all and now i have a 2" primaries rather than 1 3/4". another benefit i can verify i terminated all my connections properly thru the cannon plugs...
Old Dec 27, 2015 | 04:17 PM
  #68
Avarookie's Avatar
So, have you had a chance to get to the dyno yet? Very curious to see if the changes made significant gains or not.
Old Dec 27, 2015 | 08:36 PM
  #69
Briou's Avatar
Man I really like those firewall connectors....where did you get them? Price?
Old Dec 27, 2015 | 09:20 PM
  #70
Firebirdmuscle's Avatar
very nice build you have here. I am currently debating between a heavy powered all motor 454 or a procharged 402 build.
Old Dec 28, 2015 | 08:41 AM
  #71
D9HP's Avatar
They look like military style circular connectors. Most rugged connectors like that are produced by Amphenol, which is what I would recommend using as they are absolutely bulletproof.
He said he used them in the service but they don't look to be like the Amphenol brand. They actually look nicer with a cleaner finish. Either way you can find them on Digi-Key.
Here's a small 10 pin mated pair example:
http://www.digikey.com/product-detai...70)-ND/1209830
http://www.digikey.com/product-detai...25)-ND/1209779
Great build - I'm following along!
Old Dec 28, 2015 | 08:56 AM
  #72
Avarookie's Avatar
Military here as well, those connectors work great. Once installed, they are quick, and very easy to use. To keep things simple, whenever possible either color code them, or use different sizes, this will help make it quicker and easier to use.
Old Dec 28, 2015 | 09:54 AM
  #73
LSX67RS/SS's Avatar
Hey guys thanks for the encouraging words;
Don’t think another dyno run is going to happen, the shop is closing and hes going to build pro-stock engines in Tx. Much to my surprise, he’ll be done here in Phx soon. Supposedly NHRA has made some significant rule changes for 2016 for Pro-Stock and he thinks its going to gain in popularity…bummer for me. I’ll just have to get the car down the track to get some real numbers and use the seat of my pants dyno….hopefully in 2016
As for the connectors they were Amphenol connectors but hated the amphenol catalog therefore I used www.conesys.com catalog for determine which ones I needed. I stuck with the series II plugs and sent request for quotes to several companies, Procure International inc & Interstate Connecting Components are the two I used although another member used Prowireusa.com but they didn’t have what I was looking for. Expect to pay ~$30 -40 per side (male and female) and don’t forget the backshell strain reliefs which run ~$15 ea.
I used 4 in total; 1 for my fuel system, 1 quick disconnect and the gas tank comes out
Two plugs for my Holley HP and engine gauges on the firewall and another under the driver side fender which supplies 12v to the front half of the car. I heavily modified my Holley harness to tidy up the wire run so going this route is not for the faint of heart. The Crank, Cam and O2 sensors are shielded so really thinking it thru before cutting is highly recommended.
In the military we soldered all the wires into the plug but I found that configuration difficult to source therefore I used the crimp style which requires a special crimper. I picked one up on ebay for ~$90 and love it. Its super easy to use and it’s a very good crimp, I did several pull tests and couldn’t pull one out.
As for my progress, I’m looking to finish the entire harness under the dash by the new year, its turning out nicely, very clean. I’ll post pictures shortly.
Old Dec 28, 2015 | 12:31 PM
  #74
LSX67RS/SS's Avatar
btw i love the way your engine looks...thinking i might powder coat my fuel rails black also...
Old Apr 4, 2016 | 12:24 PM
  #75
LSX67RS/SS's Avatar
Default Oil Type
understand this is potentially a loaded question and could get whole bunch of different opinions but i'm at the point of turning the key. What Oil type should i consider....we used "Driven Racing Oil XP4 (15W50) in the test cell for initial break-in.
Old Apr 4, 2016 | 12:27 PM
  #76
SSSTANG#1's Avatar
Driven BR30 for break in and LS30 after that.
Old Apr 4, 2016 | 01:53 PM
  #77
blk00ss's Avatar
This if you feel like having to order your oil online and got deep pockets lol. I run vr1 10-30.
Old Apr 5, 2016 | 09:05 AM
  #78
LSX67RS/SS's Avatar
LOL....although deep pockets is all relative I went with the LS30. However I started adding up how much i really needed with the dry sump syst and all....it was a $120 purchase for just motor oil.
Par for the course on this build... multiply my estimates by 3....damn!
thanks for the input guys.....
