Stroked LS2 vs. Stroked LS3.
Old Jul 7, 2014 | 07:39 PM
Kamaro's Avatar
Default Stroked LS2 vs. Stroked LS3.
Hi folks,
I got a new project and my plan for it is to build a stroked LS3 using a new block, but today I got the chance to buy a LS2 engine for a very good price, now if I want to stroke it (using a 4.005 bore and a 4 in. or a 4.1 in stroke) and a CNCed L92 heads and LS3 intake, will I be missing a lot of ponys compared to a similarly stroked LS3?, I dont mind losing 20-30 hp if I can save 5-6$K.
Old Jul 7, 2014 | 07:50 PM
74u's Avatar
74u
I doubt you would lose 20rwhp with the same stroke, but I can't see how you would save $5-6K even if the LS2 block was free?
I was faced with the exact same scenario and ended up going LS3 because the cost was only $300 different (new blocks).
Per Martin @ Tick, he felt the power difference from 404 (LS2) vs 416 (LS3) might be 10 - 15rwhp with everything else being equal. 10rwhp/tq across the powerband for $300 sounded cheap so I went that route.
Old Jul 7, 2014 | 08:47 PM
FastKat's Avatar
If you have a shot at a cheap LS2, get it! I seriously doubt you'd be able to tell the difference between the two. I got a great deal on an LS2 block and jumped on it immediately.
I'm not sure what your goals are, but the L92 heads are pretty good as-cast. CNC'd ones might not be worth the money if you're doing a budget-ish build. I used stock L92 heads, an LS3 intake, a 4" stroke crank and 4.030 pistons and everything went together great. I hope to start it up in a week or two. The build was a great value - I got a whole lot of bang for the buck.
Old Jul 7, 2014 | 09:06 PM
Kamaro's Avatar
Is it safe to bore a stock ls2 to 30 over? I keep hearing that you only can go 10 over max.
Old Jul 7, 2014 | 10:50 PM
yonerhottlt1's Avatar
Yea I wouldn't recommend going more than 10 over on the aluminum block. Most ppl just go 5 over...
Old Jul 7, 2014 | 11:06 PM
1989GTA's Avatar
"Per Martin @ Tick, he felt the power difference from 404 (LS2) vs 416 (LS3) might be 10 - 15rwhp with everything else being equal. 10rwhp/tq across the powerband for $300 sounded cheap so I went that route."
There was no price difference from a 416 (LS3) to a 427 (LS3) so I went the 427 route. The down side is they do not recommend power adders. I won't be using any anyways. I have to get a new short block for my L92.
Old Jul 8, 2014 | 05:51 AM
Kamaro's Avatar
I also got the chance to get a used pair of TrickFlow 255 LS3 heads for a good price, do you think they will be a good top end to a 402 LS2 motor?, will they work well for a 4.005 bore?
Old Jul 8, 2014 | 08:24 AM
Jimbo1367's Avatar
I'd guess they'd be better than ported LS3s as they have relocated the intake valve to unshroud it. Both heads will breath better with the increased bore of the LS3. I'd personally run TEA TF235s on what ever short block you decide to run.
Old Jul 8, 2014 | 12:51 PM
74u's Avatar
74u
[QUOTE=1989GTA;18309172There was no price difference from a 416 (LS3) to a 427 (LS3) so I went the 427 route. The down side is they do not recommend power adders. I won't be using any anyways. I have to get a new short block for my L92.[/QUOTE]
I already had a 4" crank harvested from my last stroker. I just needed a block.
Old Jul 8, 2014 | 02:34 PM
JakeFusion's Avatar
Super Hulk Smash
I think the LS3 block will work work better than the LS2 when using LS3 heads... but the TFS 235 will work well on either and the difference would be probably about 10-15hp/tq as stated (just going by the difference in cubic inches). I think the difference would be more pronounced with the LS3 heads due to the valve shrouding.
Old Jul 8, 2014 | 08:06 PM
Kamaro's Avatar
Thanks guys for all the valuable info .
How much HP I would expect from such a setup?, is it possible to get a 500 RWHP from a 402 and yet get it street firendly?, my goal is having a street driven car with A/C and yet can achieve low 11s on the 1/4 mile.
Old Jul 8, 2014 | 08:57 PM
JakeFusion's Avatar
Super Hulk Smash
With a 238/246 or 242/248 cam you could have nice manners and 520+rwhp with the TFS235s...
Old Jul 8, 2014 | 08:58 PM
Jimbo1367's Avatar
500 rwhp and street friendly will require careful selection of parts regardless of which block you use. It will be even harder with a ls2 block and ls3 heads.
Patrick G or Martin Smallwood @ www.tickperformance.com would be the ones to call when you are ready to spec aa cam.
Old Jul 9, 2014 | 07:33 AM
FastKat's Avatar
That's what I read on the forums. Then I saw that ERL offers LS2 blocks .030" over. They make some nice stuff and have a great reputation. If they can do it, I think you and I can too! I think it's fine... at least for an NA car.
Also, my machinist said he would get a better rounder hole if I took it out more than .005" so I said let's do it.
Old Jul 9, 2014 | 07:58 AM
KCS's Avatar
KCS
Moderator
I'm going 4.030" on an LS2 block for my car. To my knowledge, the LS2 and 5.3L blocks are the only aluminum blocks that can go more than .010" safely on the stock sleeves. The LS1/6, LS3/A, and LS7 blocks are usually only honed out about .010" or so.
Old Jul 9, 2014 | 12:13 PM
R6cowboy's Avatar
This. LS2's have thicker sleeves than the rest of the LS blocks (except maybe the LS9). Did not know that about 5.3's though.
Old Jul 9, 2014 | 12:44 PM
Always2Slow's Avatar
I would run the TFS 255 head over the 235 head on your stroker motor.
