LS3 stroker w/cathedral cam?
Current cam is a 239/246 - .624/.595 - 113+2 which was spec'd for a daily driver 400 inch motor with cathedrals (driveability has been excellent).
Now going to Stock LS3 0821 heads - planning to mill about 50 - 60 thou to retain 11.2 scr.
I'd like to go Low-lash solid but can't afford the conversion right now. Rather than buy a new hydraulic cam spec'd around LS3 I'd rather run what I have and
save my pennies for later.
How much power do you think I might be leaving behind with the current cam vs. an appropriately spec'd HYD cam?
I found the article, I hope this helps you.
http://www.superchevy.com/how-to/ght...-head-to-head/
You'll see a tenth of a point of compression gain for every 5.8 thousands milled off 69 cc chamber heads.
