Milling L92 heads
IJS.
KW
We're already at the upper reaches of what's considered optimal DCR. One of the main reasons why these engines (the LS3's) respond so well to cam swaps, is because a 'bigger' cam drops the DCR into a better/more optimal range. If you mill the heads to raise the SCR, you also pull the DCR further away from the engine's optimal point.
IJS
KW
You have it a bit backwards, big cams usually require more compression because they lower SCR too much with long intake duration. Big cams with 10.5 DCR are going to be lazy as **** that's why you see people recommending to increase compression to benefit power and efficiency everywhere ESPECIALLY when going with a big cam.
In the grand scheme of things, leaving it alone is probably for the better as without doing anything else it's not going to gain you that much. Again, compression helps with big lazy cams. If you're not going to do that then don't bother taking the heads off just to mill them for a bit more compression.
And I recommended MORE cam, not a "BIG" cam.
A cam in the area of 218* to 224* will make for a FAR better performer than a stock cam with 11:1 SDC.
But again, not necessarily so with 'small' stock(ish) cams.
KW
