Just got my LS3 416 dyno tuned, what do you think of the redults?
Hi all, I just got my newly built 1971 Firebird Formula dyno tuned tonight, it did relatively good at 468/421 hp/tq (attached the dyno screen capture). The engine was built by me in my small garage using a stock L92 block with TSP 416 stroker kit, and a pair of GM LS3 cnc heads, Brian Tooley custom cam and stock everything else. The transmission is a Performabuilt stage 2 4L60E with EZ-TCU box. The weather was HOT in the dyno place (temp was around 105*F with humidity not less than 80%), so I think the engine did good. What do you guys think after looking at the dynograph? how many hps do you think I can get with better intake or heads?
Here is a youtube clip of the dyno run :
Well I just got my 416 LS3 running, it made 485 & 457 & IMO that's lower than I thought it would be. That's why I'm curious what the rest of your mods are. Like piston type, exhaust, cam size cuz that stuff can't be stock. This is my setup:https://ls1tech.com/forums/dynamomet...ls3-today.html
Sorry guys for not posting the whole engine specs, I had an issue with my browser that I couldn't edit my post. Here are all the info about the engine :
-L92 block
-TSP 4 in. crankshaft and wiseco -5 pistons
-GM LS3 heads that are lightly CNC ported (casting 88958758)
-BT cam 239/250@.050 with 113+3. (I think 6.02/6.20 lift but not sure)
-1 7/8 LT headers with turbo mufflers (trying to keep the noise level down)
-stock LS3 intake
-stock LS3 TB
-stock LS3 injectors/fuel rail.
-stock LS3 accessory drive system.
-stock LS3 rockers with trunion upgrade.
-stock LS7 lifters.
-FTI 3000 RPM torque converter.
-9 in. rear end with 3.50 gears & Detroit Trutrack.
-MAF tuned using stock LS3 sensor.
-The dyno place was hot like hell, more than 105F and waaaay too humid.
-L92 block
-stock LS3 intake
-stock LS3 TB
-stock LS7 lifters.
The local truck will open for test and tune in a few weeks, I'll see what it can do in the 1/4. So for this engine in a 3500 lbs car, what shall I expect in terms of ET and trap?
He's got LS3 heads not TFS or AFRs.
I don't see any issues at all with the numbers especially since ambient temps were blazing hot. Put it on the dyno when it's 50 degrees outside and it wouldn't shock me to see the exact same car pick up 50-60 rwhp.
