Best compression ratio for N/A ls7
Old Dec 22, 2015 | 10:26 AM
tn231698's Avatar
Default Best compression ratio for N/A ls7
i have purchased all the parts for my H/C/I and making sure everything is how i want it before i tear the car down. ive heard different people tell me what compression ratio is best. so heres what ive got. its a 2007 with 17k miles. i have bought PRC 285 LS7 heads milled to 68cc chambers. if i run those with stock gm gaskets ill have close to a 11.2:1 CR. if i run a cometic .40 head gasket ill be close to 11.47:1. ive heard some say 12.0:1 would be fine too. other mods include fast 102 ported to match heads, morel 5290 lifters, nw 102, callaway honker, BTR stage 4 cam ( cam motion 8620 core), ATI 10% super damper, katech red ported oil pump, katech c5-R chain, kooks long tubes, kooks o/r mid pipe, borla atak acle back, 160 therm, all arp hardwear, etc. im wanting to break 600 rwhp so i really want to make sure i dont miss any details. what CR's are all the N/A 600+ rwhp c6 z06's running?? anything else im missing that i should do while doing install?
Old Dec 22, 2015 | 10:29 AM
KCS's Avatar
KCS
Moderator
You forgot to mention what fuel.
Old Dec 22, 2015 | 10:33 AM
tn231698's Avatar
sorry. i live in atlanta and will always run a minimum of 93 octane and usually mix a couple gallons of ms109 in a tank. car is not a daily driver
Old Dec 22, 2015 | 11:01 AM
blk00ss's Avatar
That's a no brainer. 12:1 at a minimum. And if you're really going to mix race gas I wouldn't hesitate to do 12.5:1.
Old Dec 22, 2015 | 11:56 AM
John B's Avatar
Moderator
Ditto!
Old Dec 22, 2015 | 01:33 PM
MyLS1Hauls's Avatar
68 cc heads with a stock short block and GM .051 MLS gaskets is a touch more than 11.2:1. Also, the Cometic .040 gaskets may get your quench a bit tight, depending on piston-deck clearance. The pistons can be up to .005 out of the hole. That would put your quench at .035...That's absolutely as tight as I'd go, and that is not leaving much margin for error. You don't want the pistons hitting the head. You will also have to verify PTV clearance. Measure your piston-deck clearance, and then you'll know for sure, where you stand.
I put 25k on my 600rwhp setup, running around 11.7:1. I only ever ran it on 93 octane. My new setup is going to be crowding 12:1 now, due to different pistons. Its going to be on the edge for pump fuel I feel. Some say 11.5:1 is too much for pump fuel, but I know quite a few who are doing it, without much change to the timing tables.
Old Dec 22, 2015 | 01:54 PM
tn231698's Avatar
so whats your recomendation? make sure ptv is good with cometic .40 and let it go? just curious, how are these guys running 12:1 on stock bottom end?
Old Dec 22, 2015 | 04:33 PM
MyLS1Hauls's Avatar
If you check how far the pistons stick out (ideally check cylinders 1,7,2,8, as they may not all be the same), and it is less than .005", then I'd possibly try the .040 Cometics. Some claim that Permatex copper spray on both sides is required, to lessen the chance of coolant leaks. May want to look into that. I haven't personally used them. Have you talked to Tooley about it, since you're running his cam? Know that running quench distance that tight is pushing the envelope...will help resist detonation, but there is less margin for error with piston/valve/head contact. EDIT:Cometic does make a .045 gasket as well, so that would buy you a bit more piston to head clearance, if you felt it was required.
As far as 12:1 on stock bottom ends...a .030" cut from stock heads (65cc chambers) and a .040 head gasket would get you there. Would just have to make sure there is no PTV clearance issues, as you just moved the valves .070" closer to the pistons.
Old Dec 22, 2015 | 05:12 PM
tn231698's Avatar
i emailed Jared at BTR and he told me ge thought 12:1 would be fine too. you obviously know a lot about these set ups. knowong you had a 600 rwhp setup and thats my goal also, would i be better off cutting the heads down to 65cc?
Old Dec 22, 2015 | 06:39 PM
dogsballs's Avatar
35thou quench is spot on. Anything in the 12.0:1 region will make things work
Old Dec 22, 2015 | 07:52 PM
SHovV's Avatar
I'll be at 12.2 w/ .040 Cometics on my 442
Old Dec 23, 2015 | 10:35 AM
KW Baraka's Avatar
.....if i run those with stock gm gaskets ill have close to a 11.2:1 CR. if i run a cometic .40 head gasket ill be close to 11.47:1.....
I have a set of never opened .040" LS7 Cometic head gaskets that I won't be using.
PM me for a price lower than any vender can/will sale them for !
KW
Old Dec 23, 2015 | 10:36 AM
KW Baraka's Avatar
Damn straight!
.....Know that running quench distance that tight is pushing the envelope.....
No....not at all. Going less than .030" is pushing the envelope.
Going .035" is an ideal goal for a daily driven, high performance street build. At least, that's what every Hi-Po engine builder I've asked have said......
KW
Old Dec 23, 2015 | 02:35 PM
MyLS1Hauls's Avatar
Originally Posted by KW Baraka
Damn straight!
KW
I've seen some LS setups with supposed .030 quench that had piston to head contact...When you are getting this close, your measurements had better be spot on. Piston to bore clearance can also have an effect...the looser the pistons fit, the closer the piston edges will get to the head, as it rocks over at TDC. Rod bearing clearances, rod material, and max operating RPM can all have an effect on minimum safe quench as well.
The OP can do as he chooses, but for an engine such as this, I choose to err on the side of caution. I'm not going to tell someone across the internet to run tight quench, and act like he can do it without thinking twice about it. Last thing I want is for someone to pinch the ring lands, because of advice they received from me. He runs it a little on the wider side and he'll be fine, but a little too tight, and he'll be tearing the short block apart.
TN-If you're serious about being ok with mixing in some MS109, then I'd cut the heads to 65cc, and run a .040-.045 gasket. That should get you to just over 12:1. If you don't want to worry about race fuel, then leave the heads where they are, and run a 40-45 gasket. Good luck with your decision.
Old Dec 23, 2015 | 03:05 PM
C5_Pete's Avatar
Any chance you have E85 around there?
Old Dec 23, 2015 | 08:18 PM
tn231698's Avatar
yes we do. they just built a station 1/2 mile from my office that has 4 different selections of e85. however, intake occasional trips out of town and not sure if it would be available there. also, i would have to upgrade fuel system to run E85 right?
Old Dec 23, 2015 | 10:22 PM
Millenium Z06's Avatar
I'm at 12:2 on my 434, run pump 93
Old Dec 24, 2015 | 02:10 PM
C5_Pete's Avatar
You mentioned you're looking for 600 at the wheels, so I figured you were going to upgrade your fuel system anyway.
I have a Walbro 255 in tank with a hot wire kit and 85lb injectors. I'm at 14:1 on E85 and log 65% duty cycle. I log fuel pressure too and it stays strong all the time. I have the stock C5 filter/regulator along with the stock main feed line to my fuel rails.
But, I certainly understand the concern about availability when taking a road trip.
