Ls3 valve springs fit 243 heads?
Have you done any research that indicates it is a good idea to use an L99 cam.
What I have found
Vs.
LC9 Camshaft Lift (in.):
.467 intake / .479 exhaust
Camshaft Duration (@.050 in.):
196° intake / 201° exhaust
If those numbers are correct and figuring the L99 cam is meant for use with VVT and rectangle port heads I would call this swap misguided, wouldn't do it with free parts.
What I have found
L99 cam specs: 0.500-inch intake/0.492-inch exhaust lift, 195-degrees of duration intake and 201-degrees of duration on the exhaust
What I have found
Vs.
What I have found
Vs.
