Has anyone used coating on your pistons?
Has have any of you done your own piston coatings on the top and skirts.
Have you used Techline Coatings like CBX for top of piston and DFL 1 for skirts?
What do you think. I hear there are some good advantages to coating to pistons.
Have anyone had any issues?
Thank you,
Chrsitian
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
The pistons I have seen with the coating on the sides, the cylinders always seem a little better than when you don't. As for the top piston coating, it won't stop you from burning one, but it might save you once or twice.
There is another coating out that I can't remember the name of that actually gets put on to the point of an interference fit and is designed to wear into the bore quickly, this is designed to stop piston rock, and supposedly makes a substantial improvement, but I can't recall the name of it for the life of me. It's relatively new, and has been tested in the motorcycle roadcourse world a bunch with really good results from what they claim.
I have not used this, nor do I know anyone that has, but I do plan on having my engine builder look into it when I have my motor apart for upgrades, or build my next one whichever I end up doing.
http://swaintech.com/race-coatings/
The exhaust coating really does work. The piston coatings would let me run much higher egt's
Also the interference fit coating your referring to is an APC coating done by Line2Line
The line to line coating is correct that's the interference stuff that was developed in super bike applications. It would seem to make a lot of sense to put to use in a drag engine, but I don't know anyone with first hand experience
The diamond coatings are great. We have built motors with several thousand sets and they are mixed coated and non coated. We have noticed that the coated skirts do have a cleaner cylinder wall after a season of racing but also noticed that on a daily driven vehicle the coating depletes rather quickly so the protection on a driver is relatively short term.
The moly based skirt coating Diamond and other manufactures apply is a sacrificial coating designed for initial break in protection really. It will wear away in engines that see a lot of run time.
The coating is designed to wear into where the piston is happy in the application/power level.
As a piston manufacture your consistently trying to run them as tight as you can without sticking them to help reduce piston rock. With that being said they're going to air on the side of caution (loose) every time.
