L92 bearing clearences
Old May 5, 2016 | 09:19 PM
ricardo.benin's Avatar
Default L92 bearing clearences
Hi I am re building my L92, I plan on just doing a mild cam, anyways by main and rod bearing clearence is .002 which is consistent on all bearings, anyways do you think I should tighten up clearences on rods with a calico coating? The engine is pretty much a sticker
Old May 5, 2016 | 09:20 PM
*stocker
Old May 6, 2016 | 12:57 PM
Gray86hatch's Avatar
Mains are perfect. I like the rods a touch looser than that but what you have will work
Tim
Old May 6, 2016 | 04:12 PM
Yeah I thought to go tighter on rods haha, it's a pretty much a sticker with mild cam, I am doing all forged internals, because I am going to supercharge it, with very low boost and probably water/meth injection to prevent detonation
Old May 6, 2016 | 04:21 PM
HoustonSpeed_Bert's Avatar
I think your mains are a little to tight. What are you checking this with plati gauge?
Old May 6, 2016 | 04:34 PM
With a aluminum block .002 is as loose as I would go if you want it to have oil pressure at hot idle. Rods you might want to see if you can get a set of x bearings and use 1/2 for a extra .0005 clearance.
Old May 6, 2016 | 06:16 PM
Wouldn't it be the other way around the tighter the more oil pressure. I have .002 bearing clearence on mains, I was thinking of going to have the main bearings coated to close up clearence.
Thanks
Old May 6, 2016 | 06:19 PM
Thanks
Read wrong, should I get mains coated by calico.
Old May 6, 2016 | 06:53 PM
I would just buy the coated bearing from clevite if you want coated bearings. Using coating to set the clearance is not the way I would do it. You will be fine where you are at
Tim
Old May 6, 2016 | 07:05 PM
KCS's Avatar
KCS
Moderator
On something like this, I would set the mains and rods at about .003" and have the bearings coated by PolyDyne here in Houston. The coating drops the clearance down to about .002". Most power adders on "low boost" rarely ever stay on low boost. When that bug hits you and you swap the pulleys for more manifold pressure, the coating can be sacrificed without hurting the engine when more clearance is needed for the higher power level.
Old May 6, 2016 | 11:00 PM
How much rpm.do you plan on turning?
Old May 7, 2016 | 02:38 AM
Rpm, are not going to exceed the stock rev limit as this is going to be a daily driver, but like posted above I should just keep what I have?
