Iron Block 6.2 Build Recommendations
Eddie
Driver-ability/reliability? Then - keep the Cathedral, have them ported have someone spec you out a vicious mid range cam. And enjoy your stout 6.2 liter engine. It's going to haul *** & groceries!
Eddie
I'm using a 6.0 block, bored 4.065, using L92 pistons. the pistons came in a box, direct from Mahle, and have none of the clearance/bore size information on the label on the box. also, they normally have clearance etched into the top of the piston (in the case of OE replacement pistons). these do not have the "spo" number (Mahle rep says this is "german for clearance") etched into them, and therefore have no such manufacturer's recommendation. In addition, any clearance spec'd would be for that piston in an aluminum block, since that was the OE application, and Mahle does not have specs for putting said piston in an iron block since GM never did it either.
That said, Thanks for your insight, KCS, that's where I was thinking we should be. usually factory clearance is .0007 for LS1 and LS2 pistons, so we were thinking add .001 for a total piston-to-wall clearance of .0017 which is dead in the middle of what you used. thanks for the reply.
If anyone else has any input, feel free to add it.
The block in question is a 6.0 block my machinist has, it needed to go 4.056 before it cleaned up the scratched cylinder. I went ahead and got new pistons since 3 of the ones I had were questionable. The idea is to build a stout 6.2 in an iron block so the client can pull a trailer or haul whatever to his heart's content without any structural issues. The truck is a former tractor pull truck and I'm concerned it may rip the main webs apart when the chassis flexes under load.
Bolt on and cam only LS3's do near 500 rwhp, you should be able do the same especially being that it's a stick car.
