Result of Seat/Open pressure vs. Coil Bind
The advertise coil bind is 1.070"
Seat Pressure is 130lbs @ 1.800"
Open Pressure is 395lbs @ 1.150"
The camshaft max valve lift is .622".
Target is 0.050 coil bind at max lift.
Consequently install height is 1.742"
My question is what are going to be Seat and Open Pressure with the new install height?
Christian
Thank you KCS,
Listed is... Rate Lbs/In : 408
Christian
I just got off the phone with Dave at PSI, and he says that is a great set-up as long as I will be accurate with the install height...which I will triple check.
Christian
