Collapsing Lifter - Upgrade Recommendations during Repairs
This is a daily driver, so nothing too extreme. I realize once I'm down there I'm 90% of the way to replacing the Cam, but that's not in the budget at the moment. More or less looking for suggestions from the experts and enthusiasts here for Lifter/Rods/Heads/Intake upgrades that aren't breaking the bank and provide decent power gains without too much or any sacrifices.
Looking to see what you guys and gals have done, the results you got and what you would have done differently (if applicable). Brands to shy away from? Wish you would have spent X more and got X brand instead?
I've heard a lot of good things about the LS6 Heads/Intake, but does everything bolt up without issue?
Thanks in advance!
Get a set of morel 5315 lifters, BTR stage 1 cam, BTR platinum springs, gm replacement oil pump, LS2 timing chain, hardened push rods(after measuring for correct preload). 800-1000.00 for 40whp.
Heads will add another 1500.00+ to the budget. AI HC 241's might be a good alternative here. 30-40whp gain
Fast Intake and TB will cost another 11-1200.00 for 10-15whp. Porting it will free up another 5-8whp.
The harmonic balancer is known to fail on the C5, and an ATI fluid damper is a nice upgrade. I am not sure about the f-bodies.
I am on a Melling oil pump.
We also have the ls7 lifters for $99 or lifters and trays for $139.
Our pushrods are $70 atm and swapping to a budget set of pac1218 will handle a few cams out there. $139 and new seals are $25.
The gasket install kit with head bolts runs $120. include intake gaskets for $22 more.
Id take a look at your knock sensors while you are in there.
Make sure the oil pressure sender is good.
Do the tb coolant line bypass and you should be all in for most of the free mods.
Id at least have the heads surfaced at the machine shop and maybe a valve job while you are there.
I think for a daily setup you should go with a mild cam and a set of AI HC 241 heads. Again keep cam overlap around 0 and you will have a solid 400whp setup that makes power everywhere and drives damn near like stock.
So send the heads to AI and grab the cam kit from WS6 store. Maybe the new Hot Cam variant or something along those lines.
By the time you get 8 and have them sent off and cleaned and flowmatched youll be pretty close in total cost to the fast new ones. they flow 42lb at 58psi also. 36 at 43.5.
If you really want to keep extreme budget look for used cam and buy NEW springs to match cam, new LS7 lifters, new head gaskets + bolts and a Tune is a must do.
If all that is too much work and $ for ya get some LS7 lifters ( stock replacements ) head gaskets and bolts and check valve springs once apart, roll pushrods on mirror to check for straight. No tune nec, will run same as now only no ticky
