Did I crossover to the dark side? (Square port porn inside)
Old 08-25-2017, 01:03 PM
  #41
blk00ss's Avatar
It is a freaking monster. That TB came with the intake. I'm gonna try it, but if it doesn't clear the hood I'll get a thinner one. lol
Old 08-25-2017, 01:40 PM
  #42
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
Originally Posted by AnotherWs6
Your toaster is kinda getto, lol.
I'm sure many would call my 239K miles dd 05 Focus ghetto as well!
Its sacrifices we make to spend our money on the best parts for
Our obsession rather then needlessly replacing or upgrading
Functional equipment.
Seriously congrats OP for chasing your Max Combination!
Those are BBBBAAAAHHDD TO THE BBBBONE Pieces!
You will be rewarded for your decision!
What compression, Peak HP RPM & Shift Pt. are you targeting?
Old 08-25-2017, 04:17 PM
  #43
blk00ss's Avatar
Yeah someone laughed at my tile counter tops on Facebook lol. Told them I can't afford granite on a race car budget lmao. I was single when I bought my house. And truthfully I bought it because it had a new 50x30 shop with two 12'x 12' roll up doors. Priorities man.
Compression is 12.5:1. Looking to shift around 8k and spin it just a hair higher than that. It will mostly be on race gas this time as well, since I'm doing a very healthy shot of dry nitrous. Needs full race gas when spraying. No stand alone in this car. So I picked up a 54 gallon drum of Renegade 120N the other day.
Old 08-26-2017, 07:49 AM
  #44
AINT SKEERED's Avatar
How will you fit that intake under the hood? They are masterpieces but clearing an fbody is going to be interesting
Old 08-26-2017, 11:41 AM
  #45
blk00ss's Avatar
The cowl has been cut all the way to the windshield and it has a 6" Sunoco cowl hood. If it still doesn't fit, I'll go with a thinner throttle body. Of that doesn't work, I'll cut the hood lol.
Old 08-26-2017, 01:18 PM
  #46
AnotherWs6's Avatar
How much did that drum of fuel cost you?
Ever look in to Torco? Not the same as race gas but a half can to a tank would probably be more than enough for street, off the bottle stuff. I've tried it and it works. To what extent I'm not sure, but if you're borderline and/or getting slight knock on pump gas this will take you the extra step to be safe.
Nothing is gonna beat race gas, just thinking it must be expensive so if you put a decent amount of miles on the car......
Was only busting ***** about the toaster BTW.
Old 08-26-2017, 03:11 PM
  #47
I add Torco when i spray mine. on motor i can only run 26degrees of timing on motor so i add a can and get an extra couple degrees timing but dont pick up power so i use it as a safety margin when i spray 100 shot dry kit and pull 4 degrees timing.
Old 08-26-2017, 03:22 PM
  #48
blk00ss's Avatar
$625. Better than $75/5gal drum lol
Old 08-26-2017, 04:21 PM
  #49
Zmg00camaross's Avatar
Did you have a talk with your cathedrials before this??!! "I love you guys but no one in the aftermarket wants to build stuff to let you breath!"
Old 08-26-2017, 06:32 PM
  #50
LOL!
Flat on my back recovering from minor procedure.
Laughing hurts good.
Old 08-26-2017, 07:56 PM
  #51
blk00ss's Avatar
I was really upset with them. I could even look at them when I was pulling them off the engine.
Old 08-27-2017, 09:16 AM
  #52
What did the Frankenstein 237s flow? I was looking at their sight and dont show flow numbers.which i know that numbers are not everything. I looked at TEAs sight on the 235s and those are impressive.
Old 08-27-2017, 09:26 AM
  #53
blk00ss's Avatar
Not sure. Never had them flowed. Never cared to. Flow numbers have never been high on my list lol. They can vary so much from bench to bench.
Old 08-27-2017, 10:08 AM
  #54
I'm not sold on flow numbers alone. I know Frankenstein is an excellent porter so was just curious about it.
Old 08-27-2017, 10:23 AM
  #55
Received 3,111 Likes on 2,426 Posts
I don't think Frankenstein flows anything he does. Goes only by the dyno, and track numbers.
Old 08-27-2017, 10:57 AM
  #56
Jimbo1367's Avatar
268/290 .783/.801 on a 117+5.
Oh...... a smallish cam?
LOL holly chit.
Old 08-27-2017, 11:02 AM
  #57
That way when an intake valve is open he can just send a guy down to scrape carbon off the pistons if necessary......
Old 08-27-2017, 11:04 AM
  #58
He done a friends sr20 heads for his big block and did not send a flow sheet. Thats what he told my buddy, dyno it and if they dont make the power you expect then we will talk.
615 made 1275 crank hp with an 1150 carb. Tried like craxy to find a 1500 ish carb as it wanted more carb . Would have tickled 1300 had he found it but very happy with the work.
Old 08-27-2017, 11:13 AM
  #59
Put a pair of 800's on a dual quad manifold; IF one exists.......
Old 08-27-2017, 07:26 PM
  #60
blk00ss's Avatar
Got the new wheels on with a set of old 28" slicks on the car. They look small on there. Pretty sure I'll go back with a 29" so it'll look right lol.
Quick Reply: Did I crossover to the dark side? (Square port porn inside)
