Iron block 5.3 build for torque
Need a little direction because I'm new to these things, I'd prefer NA and a some comfort to it that the original 400 wouldn't offer but I'm going to need more power if I want to do this change.
So to start, internals are going to be replaced, unsure on if a stroker is the way to go but I'd like some advice here. Thought about just a stockish rebuild with the 4.8 pistons for extra compression.
Next is heads, I have the stock ones but I'm not attached to them. Port? Rebuild? Replace?
Cam I'll address later, something streetable.
The wiring harness is already scaring me but that's way down the road.
what intake do you plan? not sure what will fit in the trans am but the nnbs truck intakes are suppose to be a cheap higher flow intake then the stock older one. or just get one of those holly high rise put in.
Get some 243 heads, have a stage 1 porting done from TSP-PRC or someone reputable, keep stock valve sizing. Have them milled to achieve 10.5:1-11:1 Compression. Thinner head gasket to achieve 0.032-0.035 Quench for best burn and to allow more timing without knock, will also raise compression slightly.
A TSP 212/218 .600/.600 112 LSA is the biggest Cam I would go with for torque and using stock converter.
Stock Rocker Arms with Trunion Upgrade, BTR .660 Platinum Dual Springs, Tick Performance 0.105 Wall Pushrods to correct length.
Gen4 5.3 Truck Intake with LS7 90mm Throttle Body, possibly port the intake. Stock Gen4 5.3 FlexFuel Injectors and rails.
Then all the other goodies such as LS2 Timing Set, Melling 10295 Oil Pump, Sac City Corvette Billet Oil Barbell and if using a Gen3 Oil Pan get their Oil Bypass Delete, ATI Damper, and so on.
Now this is my opinion on an all out Torque 5.3, this will put you around 350 rwhp using an Automatic. Cam and valve sizing can change if you go up to a 349 or a 383ci.
226/234 109+6, .525/.525.
Not the best cam for power, but it sounds INSANE and makes pretty much instant torque when you stomp the throttle.
If you want power, get something else.
Haven't decided on intake yet. I was looking at a few different things. One I'm considering is the edelbrock that has a throttle body intake but still runs rails so I can run a factory style air cleaner in the car and make it adapt to my shaker and keep it functional. Otherwise, it will just be sitting on top not doing anything.
You dont HAVE to go to gen4 rods since you have the gen3s. They are an upgrade but no real need to throw more money at the thing since the gen3 are a nice rod anyway.
Thats what i would do and have done.
If you're going with a single plane efi style intake youll def want the cubic inch to combat what that intake will give up on the bottom since they dont make a dual plane efi.
If you want more info let me know!
You can also email me
Rpmspeedtech@gmail.com
Stock rebuild with flat top pistons
Ported 243 heads
I may not go with an all out torque cam, maybe something a bit more balanced, torque is fun, but I don't want it to fall on it's face, I can run taller gears and have more RPMs and it should be a little more fun in the small car.
Intake is tbd, we'll see where I go with that.
I'll probably run a t56 tranny if I can find one I want to use. I would really like to go manual but I have an auto I can stick on there if I need to.
I'd like to see hp and tq numbers over 400 or even easing in towards 500 if possible, but I'm afraid NA that isn't gonna happen.
Building an iron 5.7 will get you closer to what you want really.
I already have this block so I think I'll keep going with it.
I do need to replace my crank so a 4.0" one may be what I need.
The 90mm air door is Drive By Wire, I offer a Drive By Cable conversion for $135.00 that fits the "square bolt" motor mount. (includes the TPS)
I believe your stated 1999 ECM is DBC.
I like the 212/218 cam duration choice, I would put this on a 116 C/L which is better for your converter AND better for planed C.R. increase.
I can provide the forged crankshaft both 3.622"/4.00" (1850 Bob Weight) that could save you much of the costs required for engine balance.
As stated, new crankshaft, rods, pistons, rings, bearings at $1500 + balance cost = $200.00.
I can supply the forged 4.00" crankshaft, forged pistons, forged rods (ARP), King Bearings and NPR Rings, balanced for $1850.00 FOB.
Lance
