Cathedral vs ls3 test on a 408
Sorta poking the bear with this. CSA is pretty important and every port has to make a turn as it approaches the valve. A raised floor higher ceiling makes for a longer runner which pours more CCs but carries a straighter shot at the back of the valve The CSA tends to dictate the runner's velocity which creates tumble and turbulence thus keeping fuel particles small and atomized. Better quicker faster burn kernel Less emotions cleaner. More powerful
Today's direct injection no longer gives a darn what the runner is shaped like from the swirl standpoint
http://www.hotrod.com/articles/ccrp-...re-port-heads/
I would rather have the AFR 245 or something of an equivalent in a cathedral port on a 408
WARNING!! It's a buddie of mine that no longer posts here but still is a member that owns a ws6 that runs 10.4s on motor with a 6 speed. Yes it's 3700 lbs with the driver with leather seats,radio, heater, etc...
Yes it's pump gas with a hydraulic roller also. Just a simple combo. No single plane or LLSR bulls#it eithier.
Hell he went 10.4s on a M&H tire that wasn't even a full slick.
I honestly think the car will go faster on a full stiff wall slick. We all know 6 speed cars needs a great tire for traction. Then again if the motor was in a lighter camaro I could see a 10.3 with ease.
Someone show me better..... ANYBODY!!
the AFR made more power even with a cam that was speced for LS3 heads. The same exact cam mentioned earlier. I've seen AFR heads do well even with a single pattern camshaft. 1st: By Spanks13
If the CSA is the same why does the engine care if the port is a rectangle or shaped like a urinal?
Let me know when a Cathedral head gets 3.2 + CSA, so go in a corner and think about that one for just 1 sec. Let me know what you come back with!
Best post here Reads:
https://ls1tech.com/forums/dynamomet...-601-rwhp.html
https://www.corvetteforum.com/forums...g-results.html
1 more thing I see and read a lot: CC's and heads.
Ls7 heads reads 275 cc's
Vs
FRH Ls3 stage 1 heads 268 cc's
Which has the Larger CSA? If the Ls7 heads are thought to be bigger...Wrong! CC's honestly tells me nothing UNLESS we are using the same style heads. The quote above tells you why the Ls7 heads has a smaller CSA yet more CC volume. Don't Say what the Factory Can't do!
Hammer: besides NA the dope motored Ls3 heads make some HP also. Jim's LQ 408 with Ls3 heads was set up with a Hyd roller and Dome Top pistons 14:5 comp and a 400 shot =1000 easy at the crank. On motor it made 660'ish never tried the the shot...Jim Sold everything said everyone has a Ls swap and kept the BBC in the Camaro. 800 on motor and the same shot. ER racing with a shot would be around 1k also 800hp needs only a good pill. With factory heads mine you. You can make anything work. Dope/Nos motors like more CSA.
Changes- he ditched the MAF for a speed density tune and tweaked his 60ft by playing with suspension and installing a BMR xtreme rear drag bar. Results was a 10.4 on motor. Again that's pretty good for a 11.5 compression 402ci car with TEA TFS 235s right out the box, Mamo ported 102mm FAST intake and a pat G cam. Car made 545 rwhp on a mustang dyno.
