ANOTHER LOW OIL PRESSURE POST, but i could use the help.
LS3 swap, gm crate engine with cam swap, improved racing oil cooler adapter with oil cooler. running amsoil 5w30 but swapped to amsoil racing 10w30. no noises, no knocks, engine runs smooth. LOW OIL PRESSURE OF 13 at idle only, everywhere else pressure is 30-40. oil at idle low pressure only. checked my scan tool which goes off the sensor on the top of the block and my gauge is fed from a sensor off the oil cooler adapter and both are reading the same #. no leaks, etc.... never noticed this until last weekend i was running Big willow and my oil temps where getting 280F+ and i think it was because my front air dam was blocking the oil cooler air flow so i removed that today/ but as i was entering the pits last week i saw oil pressure was around same at idle but i figured its cause oil temp... right now oil temp up the middle and 13 on the gaugues. engine maybe has 1000 miles on it.
The factory wet sump will not handle Auto cross and/or road Racing for very long
Had a buddy with a 2008 Z51 Vette That had your symptoms before blowing up badly. His next Vette is a 2012 Grand Sport and since it’s a stick car has the dry sump oiling system and no problems
Oil Pressure (Minimum, with hot oil):........ 6 psig @ 1000 RPM
.................................................. ................ 18 psig @ 2000 RPM
.................................................. ................ 24 psig @ 4000 RPM
so i guess im ok...
so i guess im ok...
What are your cold oil pressure values at idle and around 1400-1500rpm?
280+ is definitely hot.
All my LS based engines have a cold start oil pressure of around 40-45lbs at 700rpms and 50-60 at 1400-1500rpms.
At normal operating temperature they are 25-35lbs at 650rpms and 40-50lbs at 1400-1500rpms.
I do see a drop of 5-10lbs when I use my truck to tow on a hot day but I don't have a oil temperature gauge but I'm sure that is the main reason for the drop.
changed oil last night and no metallic color or metal flakes.
cold 30psi on idle and raises normally with throttle. so the pump works fine. i got the 10296 pump, but i may send it back.. talked to improved racing tech support and they said im fine and to swap the pump for more psi for piece of mind.
And if it's an old motor with worn out bearings it will be on the loose side and running a thicker oil will help with the oil pressure but it sounds to me like this is a newly built engine. Do you know what your clearances are on this motor? The clearances should be fairly tight and your pressure should be 40-60 psi even once you've reached operating temp. Sounds to me like you have an issue even though 5psi per 1,000 rpm is acceptable.
Lot's of things can cause you to have low oil pressure. Improperly installed o-ring on the pickup tube. Oil pan to pickup tube clearance, pressure relief valve hung open on the pump just to name a few.
One other question: Is this an LS3 block and are you running the LS3 valley cover or have the DOD towers been filled in. This could also be the cause for low oil pressure.
