The Pontiacolypse
Old Sep 6, 2018 | 11:44 AM
  #301
AINT SKEERED's Avatar
I will start off with 255 as dont want to change what isn't broken to get the car running.
Old Sep 8, 2018 | 05:47 PM
  #302
Darth_V8r's Avatar
Moderator
Well I hit dyno yesterday. Only three pulls. The guy was pretty cool. Let me make some tweaks without charging me for the hourly rental rate. Car made 560/464, but you will see on the graph it was pretty bad tire slip. I do not think I even found peak torque. Ended up CUTTING timing to make more power, which is kind of neat. Carried like crazy after peak, which I am very happy with. I should say I did everything to stack the odds AGAINST it. 90mm TB spacer to simulate ls7 intake, ethanol free gas, heavy street tires, left air filters on to choke it back. Tried my best to call it baseline. Anyway, here is the graph.
Old Sep 8, 2018 | 05:54 PM
  #303
Darth_V8r's Avatar
Moderator
Forgot to mention --
Those are uncorrected numbers.
Fuel injectors went static during the pulls. I added fuel and AFR went from 13.1-13.3.
Guy at the shop was very complimentary of the car. Said he would trust it anywhere. So that was cool.
In a few weeks I'll go back with better tires, more normal fuel, 102 TB spacer or possibly Holley 105 TB, better injectors, so we will see.
Old Sep 8, 2018 | 06:16 PM
  #304
ddnspider's Avatar
Usually wheel spin looks more wavey than that. It almost looks like you were part throttle until 6k then went WOT lol. Either way nice baseline and looks like room for improvement. I would stick with the E10 since that's what most pumps have now though unless you always get fuel that has no E in it.
Old Sep 8, 2018 | 06:44 PM
  #305
Looks great sir. Hard to find a good/competent tuner. Where/who did you use?
Old Sep 8, 2018 | 07:05 PM
  #306
Darth_V8r's Avatar
Moderator
I tune my self. Dyno is CPR in West Columbia SC. Cool shop actually. Great guy.
Old Sep 8, 2018 | 07:07 PM
  #307
Darth_V8r's Avatar
Moderator
You would have to see the first pull that spun really bad to see it. It looked like a backwards nike swoop. That is why I though spin. He did say he eased into it to keep from spinning though.
Old Sep 9, 2018 | 09:41 AM
  #308
Guess you found the limits of the 42's ? Can't wait to see the next season
Old Sep 9, 2018 | 11:00 AM
  #309
ddnspider's Avatar
Thats what I thought lol. Bet it's gotta pull good!
Old Sep 9, 2018 | 12:54 PM
  #310
99 Black Bird T/A's Avatar
That's an impressive baseline!
Looking forward to seeing the next update.
Old Sep 16, 2018 | 03:10 PM
  #311
Darth, hows it going over there buddy? Hope all is well and your not under water. Hit me up if you need anything.
Old Sep 16, 2018 | 05:40 PM
  #312
ditto I was wondering the same.hope all is well
Old Sep 16, 2018 | 05:44 PM
  #313
Darth_V8r's Avatar
Moderator
Thanks guys. It has been ok here. Far enough inland that by the time it got here it was mostly spent. Lost power but have generator. I started brainstorming a welding disconnect on the house so I can both run a better welder AND hook generator up to it.
Old Sep 16, 2018 | 06:23 PM
  #314
Glad to hear you're OK Darth! Praying for those closer to the coast, though...
Old Sep 16, 2018 | 06:59 PM
  #315
Darth_V8r's Avatar
Moderator
Definitely. Had coastal family stay with us rather than ride it out.
Old Sep 16, 2018 | 07:41 PM
  #316
Good to know.that storm died off some, glad for that
Old Sep 16, 2018 | 08:31 PM
  #317
Yes, good to hear. Hope your family’s coastal property is AOK as well.
Old Sep 16, 2018 | 09:02 PM
  #318
Good move for the family, Good for you to take them in! Family is family!
  #319
Darth_V8r's Avatar
Moderator
Thanks guys
Old Sep 17, 2018 | 11:49 AM
  #320
blk00ss's Avatar
Thought you lived in New Mexico?
