Ls3 heads or ls9
Old Feb 19, 2018 | 08:06 PM
427BBV8's Avatar
Default Ls3 heads or ls9
would ls3 or ls9 heads work on a lsa block and blower? Which would be best for power ported ls3/lsa/ls9? Thanks guys. And does anyone sell lsa fuel rails? For some reason I can’t post on the sale section
Old Feb 19, 2018 | 08:38 PM
I would THINK LS9, only because they are for a blower motor too. They have a "wing" in the intake port that is supposed to promote swirl under pressure.
Old Feb 20, 2018 | 07:20 AM
KCS's Avatar
KCS
Moderator
The LSA and LS3 heads would work for sure, and I'm assuming the LS9 will. I know there are some differences with the LS9 heads, but I think it's mostly in the valvetrain and not really anything to keep them from working on an LSA block with an LSA blower.
You can't use the classified yet because you're not allowed to:
https://ls1tech.com/forums/user-supp...e-answers.html
Old Feb 20, 2018 | 08:44 AM
427BBV8's Avatar
ahhh I see thank you
427BBV8's Avatar
i think ls3 heads flow better than lsa
Old Feb 20, 2018 | 10:50 AM
I think ls3 heads flow better than lsa
I was speaking of the LS9 heads. I wouldn't know about the LSA.
Old Feb 20, 2018 | 05:48 PM
427BBV8's Avatar
so so is it true the ls9 heads have valve guid issues
Old Feb 20, 2018 | 05:58 PM
Not that I know of, but I am not positive about that.
Old Feb 20, 2018 | 11:37 PM
427BBV8's Avatar
hmmm ok thanks man!
Old Feb 22, 2018 | 11:45 AM
gnx7's Avatar
LSA and LS9 heads have the swirl bump in the port to increase efficiency and MPG. In actuality out of the box the LS3 head flows better. Once you fully port any of these heads they pretty much flow the same.
LSA/LS9 heads are rotocast with a better grade aluminum and weigh about 2lbs more than LS3/L92 heads
Only LS9 heads have Titanium intake valves
Plenty of people have made 1000rwhp on L92/LS3 heads.... but GM didn't make those other heads from a better grade aluminum and rotocast for nothing!
