LS build options
Here's what I have, an ls2 with unknown miles that is currently disassembled for inspection at the machine shop. LS3 intake and l92 heads that have been shaved .010 with btr spring kit installed. My original plan was to run the ls2 with the ls3 heads and a custom cam. But I know that in the end I'd regret not doing more.
So now I'm debating on purchasing a new ls3 block along with forged rods and pistons, while using the crank and everything else from the LS2, to better fit the heads and intake that I have. Another option that I'm seriously considering is buying the dart sleeved block from Texas speed with a 4.125 bore and running that with a stock stroke.
I don't have a power goal in mind but I'd like the chevelle to be able to beat most modern muscle cars.
Our complete rebuild kits are $699. Gets you everything but cam springs pr and lifters.
We can get you anything you need for peace of mind, but going in thousands of more dollars in the hole doesnt seem like as good idea as working with what you have!
Just our input though
So, given the list of options you posted, there's my answer.
Take that ls2 block out to 4.030 or more. Use the ls3 heads. Put a good rod and piston in it. Get a mid length runner fast intake. 11.5:1 compressions or so. Call Cam motion and get a custom Cam ground to shift around 7500+. It will rip ****
:blush:
It was an honest 500 horse setup that ran out strong.
You will need an Engine Control Unit, with software for calibration, a great price is given to LS-1 Tech members. (my ECU I hope)
MY Method could be MORE cost effective :
HONE your LS-2 to 4.007" AND fit my 4.1" Forged Crankshaft, Forged "H" beam rods, Forged Pistons, Steel Rings AND balanced for $1850.00, a LS 413.
The second choice if you want a LS-482 is the use a RHS Tall Deck Block and a 4.5" crankshaft.
The cost of a "sleeve block" vs RHS block is greater though many other items are included saving some money.
What is your projected cost to meet your needs ?
Lance
GM STATES not to bore LS cases in MANY manuals.
TAKE to time to Sonic Test before increasing the bore size.
Lance
