LS3 Rocker arms??
I have a lq9 block 404ci build with LS3 heads. Bought the heads without rocker arms and now need some. Completely understand that roller rockers may mean bigger valve covers.
Any suggestions?
Also, TSP has 1.72 roller rockers, but I haven't heard much about them.
https://www.texas-speed.com/p-6147-t...oller-tip.aspx
The TSP rockers, visually, look a lot like the Comp Cams Ultra Pro-magnums.....they feel REAL solid!
KW
Any input on the Comp Ultra Pro-Magnums on LS's? Run them on a couple dirt track car motors I've and never had an issue, thinking about a cam motion low lash solid roller using comps kit.
Any suggestions?
Some customers use the Harlan Sharp or Yellow Terra rocker arms to save money, but I don't have much experience with those personally.
We keep the T&D rocker arms in stock.
On the topic of valve lift, one of the great advantages of the roller rockers is the ability to add lift. Adding lift can give you a nice increase in power, but you must weigh that against durability if the car sees a lot of street miles. I do a lot a low lash solid rollers for the street with about .690" valve lift. They make excellent power and are a great choice if you don't drive too many miles per year.
