LY6 Newb build questions
Hello, popping my LS cherry. Bought an LY6 out of a 2008 wrecked and running van. I've removed the oil pan, heads, front cover etc and the engine looks very clean. I haven't pulled the rods, pistons, crank. It's going into a drag race car - strip only and have been reading and reading... My original plan was to just hone the cylinders, new rings gapped for boost, new turbo cam, valve springs, new oil pump, VVT delete. Here's my questions so far. Do I need to replace the cam bearings? I see guys doing cam swaps in cars so was not planning on tearing down the entire block. Can I pull out the pistons, flex hone the cylinders, wash extremely well, and put the pistons back in? Is this a decent plan? I was trying to avoid going the machine shop route...
