Am I breaking this motor in correctly??
I recently swapped out the ls1 in my 2000 ta for a 370 (was told this cubic inch by the machine shop that bored the 6.0 block). The ls1 had major lifter failure that resulted in the decision on replacing the block, rather than fixing it. Later I will be taking it to a machine shop to be looked over.
Anyway, I have been researching how to properly break in a motor. Found some great advice, but I want to make sure I understand and that im not going to mess anything up.
I ordered Lucas Engine break in oil 30w from summit racing. My understanding is to start the car, let it get up to temp, and to rev the car up a little. Like to 2500, 3000, 3500, 4000, 4500. But to not hold it for too long. Do that for about 20-30 min. Kill the car. Change the oil and filter.
Drive it around town for about 200 miles. going through the gears and rpm but not going wot or holding the rpms for a long period of time (example: getting the miles from driving on the highway). Change oil and filter. Take to tuner.
In case it matters the car will have these mods:
370 ci 6.0 bored .030 over
42# Bosch injectors
BTR stage 4 cam 235/242 .621/.592 111+3
BTR dual valve spring kit
3"Speed engineering 1 7/8 LT headers
3"Off road y pipe
3"QTP cutout after y pipe
Tuner has already done a bench tune on the pcm so that hopefully it won't run like crap when trying to break it in.
then over another 20 the engine got ramped to full rpm and held for 10.. Every builder has their own theory,
no two alike far as I can tell. But seeing a lot of various motors torn down the interesting thing is race motors get wear in
very specific points, rod bearings, rings, cam thrust and main, I often saw engines with 1 session at the dirt track opened while
we worked on development and never noticed much obvious difference other than the guys who don't spin them hard,
break them when they do and there is usually signs of the compression ring hanging on the ridge at the top of the cylinder..
I always went with ,, ramp it up to get the cam and lifters broke in, then break it in like its going to be run..
Mercedes used to dyno break in their engines for the 190 at 8500,,, and every few dozen engines they ran them to 10K..
Porsche did similar pre 1995 ish..
42# Bosch injectors
3"Off road y pipe
Sounds good except make sure the tune is safe/good before even starting it, and if you've change a lot of things I would tow it to the tuner and have them check over things on the initial startup. If the tune is far off you risk washing the rings with fuel and ruining everything, fuel will get into the oil and you'll be rebuilding again
Also a good plan
Just fill with break-in oil, start the engine, check for leaks, and then put a load on the motor. You can do so by driving it and bringing the motor gradually up to about 3-4K and then letting the motor wind back down in the same gear a few times, or do the same procedure on a dyno. Then shut her down and let her cool. The rings will either seat or they won't. Leave the break-in oil in there for a few hundred miles before changing it out.
How many times/miles would you get on the street and bring the motor to 3-4k rpm like you explained before going to get a street tune? Like I mentioned above, I already had a street tune but after changing things my tuner did a bench tune for the new build plan. He told me he would do a street tune once the break in was complete and that I would be fine to drive it around.
Rings are rings. And cylinder liners are cylinder liners, doesn't really matter if it's an LS or not.
I always run an engine that's fresh for a bit till it gets to operating temp then shut it down and let it sit a bit. Then take and easy drive letting it rev lightly and then I park it and let it cool down then I drive it again and get into it just a hair more then rinse and repeat a few times and it should be good to go.
I've read many different ways of breaking in a motor. Some people break them in right away hammering on them some do lots of heat cycles and they all seem to break in just fine.
Mainly I would say don't get it in it and start hammering on it, even though some people do and theirs seem to do just fine.
- fire it up and check for leaks and proper oil pressure
- give the motor a few gentle rev's (not to exceed 3K RPM or so since the motor is cold) to ensure that there are no issues with fueling/timing/MAF etc
- immediately take it out on the road driving it gently until operating temp is reached
- proceed to 1/2 throttle acceleration once in 2nd gear to 4K RPM and let off throttle, leave in 2nd and when motor is down to about 2500 RPM (do not lug the motor!) half throttle again to 4K RPM 3 times/decelerate
- same as above to 5K RPM this time using about 3/4 throttle 3 times
- same as above to 6K RPM with 3/4 throttle 3 times
- blast it through the gears to redline with no deceleration! Done, it's broken in!
