LS7 Lifter preload??
And since LS1 and LS7 lifters are the same size and everything would the preload be the same for both lifters? My measurement was with stock ls1 lifters
this website also agrees with TSP. Between 1/2 and 1 full turn of preload is on the money. Can someone explain this?
I do not really go by turns, I measure and trust my measurements. A half turn is just simply to light for Ls7 lifters. I run a aggressive cam with Ls7 lifters at .075" and my valve train is perfectly quiet. At .050" you will get a little sewing machine sound.
However, let's do the arithmetic (it's not really "math")... the usual LSx rocker ratio is 1.7:1. The bolt is at the fulcrum: there is 1 arbitrary unit between that and the push rod, and 1.7 of the same arbitrary units at the valve. The push rod end therefore moves 2.7 ÷ 1.7 times as far as the bolt does, as you tighten the bolt. The bolt thread pitch is 1.25mm. 1mm is about .03937", making 1 turn of the bolt about .049" at the bolt, which is then about .078" at the push rod. Which is just about perfect... the LS7 lifters want something around .075" - .080" ideally. At ¾ turn you have just a shade under .060" which is at the far low end of the desirable range, at best. .025" more PR would put you into the sweet spot. At ½ turn you'd have WAY too little (about .039") and you could expect it to be noisy.
It is, or at least should be, unnecessary to worry about the torque on the bolt. Once the bolt becomes "tight", the only thing more torque does, is make it "tighter". The parts don't move anymore because they are already tight up against each other. Sure, you may get a couple of .001"s of add'l motion if the rocker trunnion seats further down into the stand or some such, but it won't be significant. Worrying about the exact torque on the bolt is "measure with micrometer, mark with chalk, cut with axe".
I prefer to just install the rocker, adjust the adjustable PR to take up all the slack in the system i.e. zero lash, count its turns to determine its length at that point, and order PRs about .075" longer. A no-brainer. Since I have no brain, I am uniquely qualified for such things. I prefer to keep everything I do on this level.
-get a adjustable push rod, 8" digital caliper, and measure the adjustable pushrod at zero lash with the digital caliper.
-add in the desired preload to the length of the pushrod measurement @ Zero lash.
-That should be your required push rod length.( Zero lash measurement + preload)
*You can check your measurement buy counting the bolt-turn as a secondary.*
-Set the adjustable push rod to the Zero lash measurement + preload length. For example if zero lash gives you 7.3 then you add .070 for preload...that equals 7.37
- Install it and Count the bolt turns. Should be around 1 1/4 turns to 22ft lbs.
