Lost oil pressure 09 4.8. Need help
I have an 09 Chev Express 4.8 2wd. I was coming home from a trip and the girlfriend alerted me to a ticking she heard a few minutes back while I was getting some rest. Looked over and saw low oil pressure. I think it was about 15psi cruising at 65mph. We pulled over and idled. It went to 6psi at idle. Had it towed home. You can hear valve train ticking. No clunking or anything too horrible sounding . I did alot of reading and isolated the new radiator I installed prior to this trip fomr the situation. I changed the oil filter and oil. I dropped the pan to replace the o ring that mates the pickup tube to the oil pump. O ring looked in tact and tube was still sealed in the pump but replaced the o ring anyway. Still read low oil pressure. Then I pulled the oil pressure sensor and saw I don't have a filter below it. Then replaced the oil pump with a new stock melling pump. I still have low oil pressure. Just tested now with a mechanical gauge and I get 6 psi at idle. I can still hear ticking. Not sure what to check now. If a rebuild is necessary of some sort then I'm not sure what I should all replace. Assuming cam and rode bearings as well as crank bearings? Thanks
How many miles on the engine?
Sounds like your bearings are worn out and your not building much oil pressure. What oil are you running in this?
Thanks for the replies guys . There 266k on the rig . I just rebuild the trans and replaced the radiator and lines while I was at it. I sadly am guessing it's bearings that or worn. Does anyone know if I can do all the bearing with it in the van or is that just wishful thinking? From what I have researched it's probably mainly the cam bearings?
At that mileage it's possible all lower end bearings are shot.
Depends on how long you can be down without the van. If you don't rely heavily on it then pull the drive line and go back through the engine and if $$ allows get the transmission freshened up!
