Project Fentanyl 408 MJ killer.
After lme and 8 months with $2000.oo and no work for setting up the head.
West Side did them in a WK. Heads with springs and rockers new wrapped up in the box like new. 2yrs ago... Rowdy heads are the reason for the wait....still needs springs and rockers
My car is a cruiser and my kids ride in it so no roll bar, already makes more power than I can use at the track with out being run off so a turbo or blower wasnt needed to reach my goals.
Next one will be built for the power it has and be able to use it. Turbo will be used for that build.
I have quite a number of friends who roll with f/i C6 vettes here in town, but none of them run HPDE's, nor do they push there cars in the heat of summer in the desert southwest....it's a whole different story there.
A sub 3000 lbs N/A car putting 600-700 RWHP in N/A form can be a handful to drive, and drivability can most certainly suffer is some of the more extreme configurations, but a deep breathing, high winding LS is my cup of tea....especially if you're road racing too.
Chris U.. moderator for NA is cool as F...and helpful ...oh yeah gotta modd the stud girdle for the larger stud.
Forgot the owners name.but he
Took his dumb as back to a larger 440 with the same high rpm. Not that he's dumb but .....$ to Blow
No Replacement for Displacement.
Wish my block had a 4.200 bore & the same 4 inch bottom end. Bigger port needed then...more $
Class, especially since he won the National 2018 Optima Challenge, and the LSFest
Competitions as well in his 2007 C6 Z06. Been going head to head with Danny for
several years now.
Eric and HPR 468's if some remember....i went and found the 1 guy on fb that competes in the optima event...and he posted about what heads were used....guy's said 265's...not ...
Needs more CC or better said CSA.
You know now why Right? Racing is a monkey see-monkey do business.
Or John B. 427 Ls7 = a Jr version...even had Darin make me a Ls7 head 1 of 1 also.
Later set up = 800+lift and min.14.5 comp 98% street....kinda sounds like John with street use?
What are your views on chamber coatings in general?
