Ls2 408 stroker
Old Sep 25, 2019 | 09:02 PM
  #281
AINT SKEERED's Avatar
Originally Posted by Mickyinks
The dyno's in Australia read about 15-18% lower than a dynojet in the U.S. So a mustang reads lower than a dynojet ?
Usually yes mustang reads lower.
If he is over 500 and an extra %15 lower,I'd put in car and see how it feels also
Old Sep 25, 2019 | 10:49 PM
  #282
bortous's Avatar
Originally Posted by AINT SKEERED
Horse **** cam motion grind and keep the rocker arms you have
That's certainly one option.
Old Sep 25, 2019 | 10:52 PM
  #283
bortous's Avatar
Originally Posted by spanks13
I think a cam change is likely going to be your cheapest option.
Sorry you're still not seeing the results you want. For what its worth, the manton pushrods were a good move.
You coulddd also...sell your top end complete and start fresh with some different heads, 1.7 rockers and 1207x springs and probably wouldn't be out too much in the long run.
The combo you have is probably better suited for someone with a solid roller and a heavy spring.
I was thinking of selling the complete top end but then it's more of a pain in the ***.
Old Sep 25, 2019 | 10:59 PM
  #284
bortous's Avatar
Hi, Ive just read thru your thread, nice build. My old engine was ls2 454ci 239/254 hyd roller , ported ls3 heads 2.180 intake with fast lsxr long runners and it had 560rwhp. On the same dyno my mate just had his ls3 408 stroker , ported heads with a 236/248 cam and oem intake make 480rwhp . The highest a 408 has made on that same dyno has been 518rwhp So if your getting 500rwhp i think your somewhere in the ball park.
I think the reading you got from your previous engine was on a very generous dyno also, are you on the same dyno with new engine ? Has it been calibrated since you had the previous engine run up ? Dyno's are variable, drive it and see how your butt dyno goes
Looks like you are from Melbourne.
I am from Geelong.
I have been using the same dyno for quite a few years.
It's a pro dyne dyno and it reads lower than the others I have been on in the past.
There was a place down here that was reading 12rwkw higher than the one I usually go to.
The one that reads the lowest is the one that is usually the most accurate.
Your mates power figure is about right.
I have the FAST with the long runners so this would make a little bit more.
As stated in the thread I either need to change rockers or maybe go with a cam motion camshaft (with less lift) with the same hardware and see how I go.
Old Sep 25, 2019 | 11:03 PM
  #285
bortous's Avatar
I always thought the US dyno figures are a bit inflated.
I usually take off 15-20% of power to match what is down here. (when I see it's on a dyno jet)
Old Sep 26, 2019 | 08:31 AM
  #286
lazerlemonta's Avatar
I have successfully beat the horsepower calculators with my dyno numbers 3 times with my "dyno jet" numbers. My car weighs 3050ish in race form made 563 SAE and trapped 135. Same dyno same car when it made 450 SAE bolt ons it trapped 131. If you take 15% off those power levels it would be way skewed. I think local to me our numbers are pretty accurate.
Old Sep 26, 2019 | 09:20 AM
  #287
Darth_V8r's Avatar
Moderator
Then just add 15% to your power figures. All done!
That there is no change makes me think you do not have a valvetrain instability issue
Old Sep 26, 2019 | 10:43 AM
  #288
bortous's Avatar
Making 40rwhp less with a bigger camshaft does not seem to me like a good result at all.
I'm thinking I am going to go with a LLSR.
Old Sep 26, 2019 | 11:01 AM
  #289
ddnspider's Avatar
Ding ding....
Old Sep 26, 2019 | 11:15 AM
  #290
Mickyinks's Avatar
I have re-read your thread and what stands out is you say your builder advanced the cam more than what the cam card stated. Advancing a cam brings the power/torque lower in the rev range, torque /power fall off faster in the top end. Usually you run th cam at whats speced.
Im gunna say your cam timing is wrong
Old Sep 26, 2019 | 11:32 AM
  #291
ddnspider's Avatar
Spanks said it best early on:
Your tuner is taking you for a ride I wouldn’t want to be on.
13:1 is fine on E85 some go much higher.
I’d stop throwing parts at it until you can confirm what’s wrong.
  • Early posts swear its not valvetrain stability, later posts swear it is valvetrain stability. The graph hasn't shown signs of valve float/instability.
  • You've spent on pushrods what a Holly Sniper intake or knock off costs that would put to rest whether or not its an intake manifold problem. Didn't see any resolution to whether or not there was still an intake restriction from the logs. Yes mid-length runners were swapped on, no response on intake restriction. If there was still a restriction then it wasn't the heads that were sent out.
  • What is the torque converter slip in high gear through the WOT curve?
  • As said a compression test doesn't tell all. Leak-down for starters and need to check for weak spark/injectors.
  • Can also measure backpressure easily in the exhaust.
  • No info on AFR/spark numbers on the pull.
You flat out need someone competent/capable of troubleshooting and less worry about making the valve covers pretty.
Old Sep 26, 2019 | 11:38 AM
  #292
bortous's Avatar
Camshaft was advanced 3 degrees because it had to be.
Camshaft came with 1 degree of advance built in and it needed another 2 degrees which it received.
Valve events are correct.
Old Sep 26, 2019 | 11:53 AM
  #293
Mickyinks's Avatar
Mayb im wrong but you cant change the centre line by advancing it more than the cam card states. The centreline is ground in.
Ive seen where a guy dynoed his cam as cam card stated, then dyno'd again advancing it 2 degrees and below 3900 it had more torgue/hp and above it had less with it losing 43nm an 50hp less at 6300rpm
Old Sep 26, 2019 | 12:52 PM
  #294
psicko's Avatar
He isn't going to listen. At this point, either the tuner is completely incompetent, or he knows he has a sucker on the hook who is willing to just keep wasting money by throwing parts at it with fingers crossed.
Old Sep 26, 2019 | 12:53 PM
  #295
Backing cam off to what it was ground for would carry rpm higher
Old Sep 26, 2019 | 12:56 PM
  #296
psicko's Avatar
The centerline is the distance in degrees between TDC and the max lift of the lobe, so you can change the centerlines by advancing or retarding the cam. The LSA is the distance in degrees between the lobe centerlines and cannot be changed since it is ground into the cam.
Old Sep 26, 2019 | 01:38 PM
  #297
bortous's Avatar
That's right.
Camshaft was a custom spec at a 242/257 113lsa +1.
In order to get the Valve events where we want them at ivc 51 and Evo 65 and 110 icl we needed the extra two degrees of advance.
Old Sep 26, 2019 | 01:42 PM
  #298
bortous's Avatar
Interesting observation.
I'm a great listener so you got that wrong.
Old Sep 27, 2019 | 10:10 AM
  #299
psicko's Avatar
I agree, you have been great at listening to bad advice. Stop wasting your money, stop throwing parts at it, and do a proper check for dead cylinders. You missed an opportunity the last time it was strapped to the dyno; your "tuner" could have made a series of pulls, each with a different injector unplugged. Any pull that didn't lose power would have confirmed a dead cylinder.
While you're at it, get a different "tuner", this one is a hack! Didn't he say that the data logs showed a restriction after the first test? So you went out and bought the shorter runners (which was a dumb idea anyways). How did that work out for ya?
Then he says that it must be the lack of spring pressure because someone didn't shim the springs enough, so you let him shim the springs. How did that work out for ya?
Lastly, he says it must be valvetrain instability, despite no signs of it on the graph, but you went and bought the stiffer pushrods anyways. How did that work out for ya?
How many more chances are you going to give this "tuner" before you wise up?
Old Sep 27, 2019 | 10:30 AM
  #300
bortous's Avatar
Good point.
I'm going to see him personally next Thursday.
All my contact has been via text.
I will update this thread once I have new information.
As stated cylinders were checked. There are no dead cylinders.
This was done at the beginning.
Even Patrick Guerra said it is those yella terra rockers and that camshaft I have which are most likely causing these issues.
And also having too much lift. He also says, the valvetrain setup I have is more suited to a LLSR and would work really well with it as it's far more stable.
I am also the one that decided to go the higher ratio and heavier rocker but I was advised against it and still went ahead anyway.
Also the camshaft, was never intended for a higher ratio.
I called up the camshaft place a while ago and told them my issue and their first response was to take off those **** heavy rockers, go back to a stock ratio GM rocker or get the ultra lite pro YT in 1.7.
This will resolve the issue I am told.
Spring choice is good though.
I will see what happens.
Most likely by the looks of things I will probably end up going the LLSR as it's the easiest way of doing it.
But we will see.
I can always sell the other parts.
