Ls2 408 stroker
Old Dec 23, 2019 | 01:14 AM
  #741
bortous's Avatar
Originally Posted by JakeFusion
And yes, a tuner would easily string someone along if they keep "paying" for the services. I'm sure Bortuous has dropped a pretty penny with this tuner since he's also installing parts and retuning. He's not doing that out of charity...
Actually Jake, the price he has been charging me has been way less than what he usually charges because of all the issues we are having.
I already get good rates and there were almost in half.
Very reasonable pricing which is why you don't read me complaining about the labour costs.
After engine is running right, remind me to state how much I paid in labour costs since the beginning.
You will be surprised,
Old Dec 23, 2019 | 01:17 AM
  #742
bortous's Avatar
Originally Posted by Launch
Do you feel you are being misled by your tuner? Spent more money than you feel you should have? Is your LS still under performing? Detective KCS at your service Call *****00049404
Are you not happy with your tuner?
Lol
Old Dec 23, 2019 | 01:19 AM
  #743
bortous's Avatar
Originally Posted by Smokey B
Bortous what are your exact cam spec's...and compression know 2 Very similar builds....major difference carb & intake...
Bored and gives me something 2 do.....talking on x1 burned out on 2k20 and Call of Duty MW......
Smoke, the camshaft specs are for a LLSR from cam motion.
250/258 .660 .660 114 LSA +4
Compression is at 12:1.1
Do your magic!
Old Dec 23, 2019 | 01:45 AM
  #744
bortous's Avatar
I already have a big comp cam already installed in the block that i'm going to run as a solid roller, it has 30 degrees of overlap. For N/A use. It's not a daily driver so not worried much about driving manners. If I do decide to keep the car N/A for good, i'm thinking around 13.3:1 cr which is where I am with flat tops (because these custom heads have only 49.5cc chambers) and run it on e85 should tame the cam a bit and make decent more power. I know it'll use approx 30% more fuel on e85 and it's not cheap here like the USA.
But if i do a lower comp ratio then I don't have to change the pistons again or remove the engine if I then decide to do a single turbo setup after this ls2 has been run and tested in the car as N/A, to make sure the valvetrain and everything else is in order. Because these ls7 heads are oddball from an ecr nascar team, I want to get it going n/a first to make sure everything is correct. I regret ever buying them but they owe me $3500 with the T&D rockers so I'm not backing out now. And ls7 heads make a lot of power boosted also, and I confirmed these do fit all the factory style intakes (thank god that wasn't also oddball) by bolting down the LS7 intake, so it's not all bad.
I will make a decision once the new year passes and finish it when I get time. I just need to measure for pushrod length and order and I already have just about everything else. The intake is an oem ls7 intake and I have a 102 warr tb. I don't see the intake being an issue? It will just flow more air than an ls6 intake. I'm thinking of it as it'll just be similar to a fast 102 intake on an LS2. I already have a 5500rpm 8" converter to go in the car (for N/A use) so any lack of torque under 5k rpm won't be an issue.
Sounds like a crazy build.
I remember you telling me about it a while ago.
They are some tiny combustion chambers.
With that high compression you will need a large camshaft and e85 would definitely benefit the combination.
When set up right that should be a weapon.
Old Dec 23, 2019 | 07:14 AM
  #745
ddnspider's Avatar
Good stuff.
Old Dec 23, 2019 | 07:30 AM
  #746
Darth_V8r's Avatar
Moderator
That compression and cam at the crank would be around 650 - 680 with a 402...
Do your magic!
Hate to burst any bubbles, but 650-680 is a high guess honestly. I'm assuming that is a flywheel number. I mean, 650 is realistic, assuming 100 hp for drivetrain losses, that would put you at 550rwhp (410 rwKW), but that's going to be the very high end, because it's an auto. Running right, this thing will end up around 530 IMO at the rear. There are other little optimizations that may or may not have been done, such as vacuum pump, manual steering, EWP, that can free up some power. and surprise you.
One thing to add though, if you are in the mid to high 4's and did have a dead or partially dead hole, it would flat our scream with all eight fully operational.
The final torque figure is 1088Nm
That's not realistic. that has to be converter flash or some other influence. That's 800 lbs of tq or 2 lbs per CI. 1.25 lbs per CI is a good rule of thumb, but I've seen as high as 1.27 NA. 2 lbs per CI outright not gonna happen. Fully sorted, locked converter, etc, the best you're going to get NA for torque (rear wheel) on a 402 is in the 500-510 (690-ish nm) range, and that is everything done right.
Now, take all of the above into account, you have very good compression and good cam events, and the fuel to support it, if you can get to 500 lbs tq around 5200 rpm, that will put your peak power at or near 6700, and a 550 rwhp numbers seems possible. But again, I'd call that the high end of what you can expect.
Old Dec 23, 2019 | 08:01 AM
  #747
bortous's Avatar
Might be converter flash.
Previous hydraulic setup was at 1148nm at the rear.
Take 30% away and its around 750nm torque at rear wheels
I think the reading went higher when I fitted the 3:91 rear gears about 6 years ago.
The stock gears were 3:46.
Subtracting 30% away its around 750nm torque at rear wheels which is what would be making with the stock gearing.
The torque output is very good considering it has shorter runners.
There is no way I will make 410rwkw even if everything was perfect.
This would be LS7 or high end cathedral territory.
Once the lifter issue gets sorted the final tuning can finally be completed.
Old Dec 23, 2019 | 08:07 AM
  #748
Darth_V8r's Avatar
Moderator
That would make a lot more sense, but is still high. 750nm is 565 lbs torque, which is optimized LS7 territory. When looking at the curve, ignore the flash, and find the peak of the curve visually.
As to power estimate, if 530hp is right, that's around 395 KW. Which if I remember from earlier in your thread is close to where you wanted to end up?
Old Dec 23, 2019 | 08:18 AM
  #749
bortous's Avatar
Well I was hoping to get around there but I doubt I will.
Years ago I remembered there was a formula to work out with rear gearing what the percentage difference you needed to subtract in order to get the proper torque reading.
From 3:46 to 3:91 it was around 30% and to 4:10 was about 37%.
Don't remember the exact figures.
Old Dec 23, 2019 | 08:33 AM
  #750
Tuskyz28's Avatar
So what date will the results be posted?
Old Dec 23, 2019 | 08:35 AM
  #751
bortous's Avatar
After the 20th January.
Old Dec 23, 2019 | 08:44 AM
  #752
Launch's Avatar
Don't forget he now has to wait for other lifters.
If you were all waiting for my results, you'd be posting 5x roll eyes. That's why I don't start a build thread and I can take as long as I like
Old Dec 23, 2019 | 09:22 AM
  #753
Mavn's Avatar
"I MAID THEESE"
**** all this dyno number bs.
Go see what it traps and call it a day lmfao
Old Dec 23, 2019 | 09:24 AM
  #754
Darth_V8r's Avatar
Moderator
He can't. Oil pressure ftl...
Old Dec 23, 2019 | 10:18 AM
  #755
Smokey B's Avatar
Yeah......let me see.....Know 4 a fact, just looking mind went straight to 700 @ the crank or close to it....Plastic BS intake....
Ok...Compare: U guy's do remember this guy....Less compression and cam......
https://www.enginelabs.com/engine-te...ild-with-ffre/
Old Dec 23, 2019 | 10:25 AM
  #756
bortous's Avatar
Smokey, be good.
Don't start with these crappy plastic intakes again.
I'm starting to hate them too.
Old Dec 23, 2019 | 10:26 AM
  #757
Darth_V8r's Avatar
Moderator
Yup! He works for Cam Motion now, actually. Big difference though. Those heads Steven used are dart Pro1's. I think he used the 15 degree heads to help with the smaller bore. OP using stock ls3 heads with a valve job.
And remember, very few engines get magazine articles made from them. If 700 were common from a 403, it wouldn't get the article.
Old Dec 23, 2019 | 10:29 AM
  #758
Smokey B's Avatar
Or this 1.....Flyin.....13.1 and a Hyd roller same Hp as Speedtrigger...*said this very same thing in the thread*....Again BS plastic intake...it's a cool intake if you want Tq...I'm not into heavy cars or trucks.. I like filling the cylinder Carb intake does it the best.
I'm Wasbi be 4 the name change....yeah i'm A hole & not just here...me and Uncle ER racing got the closest to what Flyin laid down...Also told him 800 fwhp was a cam swap....Later 800
https://www.yellowbullet.com/threads...hread.1905482/
Old Dec 23, 2019 | 10:30 AM
  #759
Darth_V8r's Avatar
Moderator
Smokey, be good.
For some reason, that reminds me. I ran your new configuration through a quick excel model based on "Bell's Performance and Tuning", and it says 2" primaries would be your best overall match. Not like 1-7/8 is going to knock 30 hp off or anything, but for making 7K rpm power, 2" with 31" length will do you best.
Old Dec 23, 2019 | 10:31 AM
  #760
Smokey B's Avatar
Take 20 to 30 for unported ....
