Ls2 408 stroker
Old Nov 27, 2019 | 07:23 PM
  #541
JakeFusion's Avatar
Super Hulk Smash
11/32nd pushrods will fit no problem and are much stiffer than the 5/16ths...
Old Nov 27, 2019 | 09:42 PM
  #542
bortous's Avatar
Yes I know.
I confirmed just now that pushrods have been ordered.
They ended up being 3/8 .138 wall at 8.4 inch length.
No way we could get those 7.800 pushrods to fit.
At least there won't be anything wrong pushrod related.
Old Nov 30, 2019 | 10:06 AM
  #543
KCS's Avatar
KCS
Moderator
So they ended up ordering 3/8” diameter pushrods? I thought they said they wouldn’t fit.
Old Nov 30, 2019 | 08:07 PM
  #544
Launch's Avatar
Originally Posted by bortous
I heard back from my tuner earlier.
He put in the lifters I purchased from howards, and he thinks he will be able to fit 3/8 pushrods in there because these lifters are shorter.
Will see what happens.
Old Nov 30, 2019 | 09:24 PM
  #545
bortous's Avatar
Well, he originally said they wouldn't fit.
When he fitted the lifters and longer pushrods these altered the angles which now allows a 3/8 pushrod to fit.
Crow cams sent him the wrong pushrods too.
They sent 80 wall instead of 138 wall.
They are resending the correct pushrods on Monday.
Old Nov 30, 2019 | 11:35 PM
  #546
AINT SKEERED's Avatar
i'm using .080 wall 3/8. Still waynstiffer than thick wall 5/16
Old Dec 1, 2019 | 12:07 AM
  #547
bortous's Avatar
I know they are ok to use and would be fine.
The reason why I requested the changeover, because these pushrods my tuner ordered, I found the same exact same pushrods on ebay for $50 USD less for a whole set.
However, I didn't check till after he ordered them direct from crow.
Now that I hear that they sent him the wrong thickness, I can't bear to hear that not only did I pay more than I had to but that they are the thinner version also.
Swap over obviously is free so I want to do it that way.
Old Dec 1, 2019 | 12:13 AM
  #548
agreed. Cant go wrong with thicker wall
Old Dec 3, 2019 | 10:27 AM
  #549
bortous's Avatar
Hey guys,
I have a quick question.
What is the max RPM limit you can spin my engine?
What max rpm is the callies compstar crank rated to?
Old Dec 3, 2019 | 11:04 AM
  #550
Jimbo1367's Avatar
That's more related to the cam and complete valve train combo isn't it?
Old Dec 3, 2019 | 11:24 AM
  #551
bortous's Avatar
That would definitely have something to do with it but it's also the intake as well.
I'm wanting to know what the rpm the engine itself and it's internals can rev out to safely.
Old Dec 3, 2019 | 11:41 AM
  #552
Darth_V8r's Avatar
Moderator
Idk max but I would not blink at 8k
Old Dec 3, 2019 | 01:25 PM
  #553
I hit 7800 to 8000 every pass. K1 crank and Rods
Old Dec 4, 2019 | 12:53 AM
  #554
bortous's Avatar
Another update guys.
Just heard from my tuner.
Engine is finally together and running.
He marvelled at how quiet the valvetrain is with that low lash solid roller.
He followed cam motions lash settings. 0.00 cold.
However, tune is way off and needs a lot of work and he can't do a preliminary run to see where it's at yet.
Looks like it will be completed in the next day or 2.
I'm in for results.
Old Dec 4, 2019 | 07:15 AM
  #555
Darth_V8r's Avatar
Moderator
You are likely fat down low and thin up top. Wait till they tell you how Amazeballs it sounds at full power. Nothing quite like it.
If anyone tries to tell you valve float now, they are full of ****
Old Dec 4, 2019 | 08:31 AM
  #556
bortous's Avatar
So the solid roller sounds that much better than a hydraulic?
How would it sound better?
There will be no such thing as valve float now that's for sure.
I think the issue all along was a mismatch of parts.
The rockers, springs and camshaft did not go well together and were causing valvetrain harmonic issues hence the lower power figure.
Old Dec 4, 2019 | 09:03 AM
  #557
Jimbo1367's Avatar
  1. Listen to Speedtifiggrts chassis dynos hyd vs sold one after another. The solid sounds SOO much better.
Old Dec 4, 2019 | 09:04 AM
  #558
Darth_V8r's Avatar
Moderator
It will have more bite to the exhaust note. It will WANT to rev. Hard to explain, but my guess is you will hear from them as they tune it in how much gooder it sounds.
  #559
Jimbo1367's Avatar
Damn fat fingers. Lol
Old Dec 4, 2019 | 09:26 AM
  #560
bortous's Avatar
Where is point 2?
