Ls2 408 stroker
. I didnt have a vacuum pump at the time of engine dyno not feel the operator brought the engine up to operating temp as he made all pulls at only 120 deg Fahrenheit coolant temp.
. My engine made peak tq of 575@5200 rpm and peak hp of 671@7700rpm.
. Chassis dyno has a vacuum pump and through a 5500 stall and 4l80 transmission, 12 bolt with 4.10 gear it made 553rwhp. True I can run a lot more cam but this thing already revs to the moon and drives like a very mild ls1.
runs 10.30 at 132 mph at 3900 race weight, so it's not a slouch either. Honestly getting caught up on dyno numbers can Get you broke. Get it to run the number on the track and that's what matters.
if not into the track then get it to pull hard in the application you are using it for.
.Ain't Skeered ..look @ your name? If you wanted x amount should have gotten with a builder who's done what your thinking....Erik@HPR? You've got a great build that your happy with..Cool!
But BS is BS and 800 isn't asking 2 much.. Maybe for some builders. Who you No has more to do with maken proven known hp and or being fast. Guy's should have a expectation of what they'd get with cam + compression + bore x stroke. Higher expectations requires different thinking.
Rule 1 Fill the cylinder with more =
so what i've read,asked,looked @ is all fairy tale...this is not a dream. Everyone has a goal and what's desired ... If u believe 800 is some hard thing with a 4.125+ bore your crazy or ......dude did it with a 6.0 block below 7500. Funny....bigger and better requires less on Cam, Compression which was below 12.0 more like 11.5 .... again funny....everyone has different expectations....
P.S. Im an HVAC guy. Im a good one too. Id run circles around you bcuz you simply don't know it. But I wouldn't shyt on your furnace that gives you heat and ac. Its what you know and accept. Heres one for ya bro that's technical_ Im heating my 3000sqft house with 110*-140* water temps and just under 60,000 total btu s, often less. Im using only 3tons of air to achieve the same comfort in 98* temps. Lotta technical stuff and details I left out, but its defly not the norm and wont work for every one of my customers. Hell it doesn't even fit rule of thumb or even anyones napkin math.
On MW3.....earlier finding....
https://www.streetmusclemag.com/feat...or-series-ls7/
Would like to know this cam specs...wink,wink 250 ish?
https://tremaniacracingengines.com.a...-roller-786hp/
Race fuel, dry sump, packaging constraints, and huge upfront costs=NOT SO EASY, IMHO
If im droppn 30k on a build, i ll take a turnkey whippled 427ci and 900+ whp to show for it.
Im gunna email Lingenfelter and ask some questions SMOKEY style. I like that set up.
Happy holidays to everyone...hopn Santa brings Bortous alil luck n progress on his motor
