Ls2 408 stroker
Old Feb 6, 2020 | 03:06 PM
  #1061
Smokey B's Avatar
ER is a *****..... No shop or selling of parts or porting but .. .Does things only the Top 1% can do or does. Gives it to me straight no Vaseline. Whether I like it or I don't. No $ involved Darin also.
I ask...I get. No matter the question or head thought about. Chris Frank...we've talked so much and he's created so many versions of LS heads...🤫
Old Feb 6, 2020 | 03:13 PM
  #1062
Smokey B's Avatar
I haven seen better Darth than Tony's TFS heads for the the typical guy with one stop shopping for the top end or complete build
GG and stock ls6 heads on a 415 ci made 600+ rwhp DD?....light bulb cut on with me seeing this yrs ago with a plastic intake. A porter can make something out of Nothing.
Old Feb 6, 2020 | 03:17 PM
  #1063
rkupon1's Avatar
Im really considering pickn up a set of those porters casting BR7 300s for a future build. But whats the point if only way to get Darins work now is call up 1-800-MAST? Same with Chris Frank, is he gunna just ask that you buy his heads? Or let you send in a set?
Old Feb 6, 2020 | 03:28 PM
  #1064
Smokey B's Avatar
You go in with what you got and state what you want. I asked for a bad MF'er and what Darin would do for his own stuff. Did cost 2k+ but we made a head for something it wasn't intended for. Chris Frank the same way... If I call Chris ... And state I want a F710 head for a small bore on par with the RHS Ls7 small bore head he did a CNC program for (back in the day) what u thinks gonna happen with $. I've been with some of these guys since they were porting Factory heads and they like me pushing them or asking. I love cylinder heads so do they, and they always show Love. I figure I'm just better with people if I'm not on Ls1tech ....I've got friends Everywhere in this industry...besides this dude Zach. We friends he's just gotta do 1 or the 2 no harsh feelings.
Old Feb 6, 2020 | 03:36 PM
  #1065
Smokey B's Avatar
Those John B heads were worth 5000+ in work 302cc btw...if you didn't know. Reason your not seeing factory Ls7 short blocks with 700rwhp. You may see others with larger builds and compression... They really trying to out do a Ls7 short block and smaller build as a daily. Some on corn. Intake choice really helped. Mast, Holley, SM, intake was so close ...light cut on
Old Feb 6, 2020 | 03:39 PM
  #1066
Tuskyz28's Avatar
Those Brodix heads are badass. Seen them on a 427ci putting in some work back in September.
Old Feb 6, 2020 | 03:46 PM
  #1067
Smokey B's Avatar
Rup Darin had or has his own thing Before Mast and if he leaves ...Mast does porting now because of Darin.
He ports and creates heads. Same as Chris ....raw aluminum creations if needed.
Old Feb 6, 2020 | 04:34 PM
  #1068
Bla Bla Bla...I’ve heard this sermon a few times already. Tell us something we don’t know Smoke. 😘
Old Feb 6, 2020 | 04:52 PM
  #1069
Tuskyz28's Avatar
Bortous- its a 416ci on board with MMS 235 heads that put out 652hp and 580 ft lbs with a fast intake and a hydraulic roller.... hope that helps
Old Feb 6, 2020 | 05:04 PM
  #1070
Smokey B's Avatar
Funny thing is they act like they don't know saying the same name time and time again...i call it the the other porters Besides Mamo on ls1tech. What you know about Slick Rick ...or Shawn Hooper ...
Old Feb 6, 2020 | 05:09 PM
  #1071
Smokey B's Avatar
Hell Chevelle...knowing the guys you know in the race world a good porter is Common. I fill the same way. Reason in asked GG and Darin to do a newer version Ls7 head test. Was told look at who's winning and has the faster ET's. From both. I ask ?'s about all Porter's and heads and there products VS one another. Generally all in the same sandlot if nothing special is done.
Old Feb 7, 2020 | 04:53 AM
  #1072
Jimbo1367's Avatar
that sounds like a great engine. What do you guys think the idle and street manners would be on something like this? Cam specs?
Old Feb 7, 2020 | 05:01 AM
  #1073
bortous's Avatar
I think the driving manners would be great.
Those heads can tolerate a lot more camshaft.
If my LS3 stroker engine with 20 degrees of overlap drives smooth down low the same overlap figure with those MMS heads would mean that the engine would drive even smoother again.
I look forward to getting these.
Old Feb 7, 2020 | 04:34 PM
  #1074
Bortous, if your looking for a Mamo top end, you won’t ever, repeat...ever find a better deal than this.
https://ls1tech.com/forums/market/1932142
You are welcome.
Old Feb 7, 2020 | 04:59 PM
  #1075
Tuskyz28's Avatar
247/252 and the CR is a hair under 12-1.
Old Feb 7, 2020 | 05:14 PM
  #1076
Tuskyz28's Avatar
Jimbo- Richard Holdener took a 408ci and made 626 horsepower at the crank.
240/246 duration cam
AFR 245s out the box
Fast 102mm out the box
11.0 compression
I say bump that compression up to 11.7 or so and let her eat some Scooby snacks
Old Feb 7, 2020 | 08:19 PM
  #1077
Darth_V8r's Avatar
Moderator
11.0 compression
That is actually a decent performing 408. Figure 550 at the tires with a t56
Old Feb 7, 2020 | 09:02 PM
  #1078
Tuskyz28's Avatar
That sounds about right. Guess I'll add another one for ***** and giggles.
LME 416ci
LME CNC LS3 GM casting heads
235/250 duration cam
Fast 102mm intake
11.8 compression
622 horsepower/575 torque
Old Feb 7, 2020 | 09:40 PM
  #1079
AINT SKEERED's Avatar
LME 416ci
Fast 102mm intake
11.8 compression
engine dyno numbers?
Old Feb 7, 2020 | 10:26 PM
  #1080
bortous's Avatar
You are welcome.
That is a fantastic deal.
I have PM'd the seller.
Bit curious why he is selling it though.
