Ls2 408 stroker
Old Feb 11, 2020 | 11:29 AM
  #1121
Smokey B's Avatar
Hope it isn't 9sec 427 vettes doing 9's
Old Feb 11, 2020 | 11:35 AM
  #1122
Smokey B's Avatar
Not limited to one forum or person.
LMAO!
Still sad 😢 about getting screwed ☹️...now posting on his FB page.🤬😠😡👿😇 I wanna see dude we have got to talk.
Not a want but a must rethink of things. Different Pistons before I do assembly again..
Old Feb 11, 2020 | 11:47 AM
  #1123
bortous's Avatar
LMAO!
As I said get some advice from Tony.
He is waiting for you with open arms.
Old Feb 11, 2020 | 11:48 AM
  #1124
ddnspider's Avatar
bortous motor is a 408.....an LS7 is a 427....you're quoting a 454. Show me 427 c.i. with a factory LS7 intake make an honest 700whp.
Old Feb 11, 2020 | 11:53 AM
  #1125
Smokey B's Avatar
Kinda sad and haven't been into engines to much....had backed off a bit also... before hand in hindsight.
I've asked all the questions I've Ever wanted to know about a cylinder head...modding or creating.
ER or Darin sometimes Scott. Dude's good but $9000.oo for a Ls7 top-end. I'm with if you've got the $ but this cost for a TFS casting and MSD intake.
When I read that 🤔 to self
self.
Old Feb 11, 2020 | 12:01 PM
  #1126
Darth_V8r's Avatar
Moderator
B, I don't need to call no one about a Ls7 top end @ 9k. I made a Ls7 head and priced building or putting together a STR8 head with a smaller port. Cost still wasn't 9k with all parts and intake.
DD spider. TSP has made 750 with a Ls7 top-end > factory intake* although a 454. Cam swap and milled heads with a 427 Ls7? Waiting on NPS response, builds all types of engines besides the LS up in Canada. Race builder? Some just don't post here... This is OLD. And he said what he said 750 with Factory heads and intake.
https://youtu.be/TJtHwejf_Ko
750 crank. 631 rwhp. 98_WS6_M6 is talking 700 RWHP, so more like 800 crank., so oops, there!
Second, it seems like the price is a misrepresentation. You make it look like $9K for the heads. That's not even close. But I'll play along...
Mast heads just the casting - $1450 each, so $2900.
Valves - $850 for 8 intake valves from manley. $250 for the eight exhaust valves
Springs - PAC 1335, since you like to run lift - $630
Cam - $450
Lifters - Assume you'll run either Jesel or isky? - $1300
CID intake - $1050 if set up for eight injectors, $1500 if set up for 16
Pushrods - $250 for manton custom
Rockers - no YT for you, so likely Jesels or T&D, so est $1500, which is probably low...
We're at $9200 now, without the expensive options, and we haven't done the setting up, retainers, locks, shimming, gaskets, fluids, throttle body not on the list yet. Can play again. Pick the porter's casting you want, then pay for CNC, and you're in the same ballpark. Brodix set up with stainless intake valves is $3600, and if you're cutting costs there, then you've already made the point.
The heads fully set up are only half the cost.
I did do a cheaper LS7 top end set up. Didn't make the power. I could make it make the power. Won't have the reliability. Want power AND reliability? Grab your wallet!
Old Feb 11, 2020 | 12:02 PM
  #1127
Smokey B's Avatar
NPS said 750 crank hp, in 2014 NPS created his own Ls7 head using more than likely the Brodix Ls7 castings. The video seen was a Factory intake with NPS created Brodix heads. NPS now says he's doing 750 with Either or head and factory intake. I'm not limited to Ls1tech and 1 builder. Ain't nothing new out here being done!
Old Feb 11, 2020 | 12:06 PM
  #1128
Smokey B's Avatar
Darth no way around 9k and TFS Ls7 heads ...Jesus himself wouldn't think of asking me to change my mind knowing who and what I know as he lead me to them. Yeah this is the reason I don't like dude ....10k for a bowl and SSR job from a TFS 260 cc head and it's parts.
Call BES and ask what 10k would get you.
Old Feb 11, 2020 | 12:10 PM
  #1129
Darth_V8r's Avatar
Moderator
Again, complete misrepresentation. Now you are saying $10k for a tfs casting and a bowl blend??? not even close to true. Anyone reading this, call Tony and quote the heads and not all the ancillary stuff.
Old Feb 11, 2020 | 12:12 PM
  #1130
Smokey B's Avatar
Any porter out here would give a better casting than a TFS that's 1st off for that price ...
Old Feb 11, 2020 | 12:14 PM
  #1131
Smokey B's Avatar
You got a complete Ls7 top end...the heads are TFS 260 CNC heads with a hand job in the porting world. Tony calls it a CNC program
Old Feb 11, 2020 | 12:15 PM
  #1132
Darth_V8r's Avatar
Moderator
...Call BES and ask what 10k would get you.
$6200 just for the heads set up and no additional hardware...
Old Feb 11, 2020 | 12:19 PM
  #1133
Smokey B's Avatar
I priced every part to the assembled LS3 I've got and any head I got or thought of making.
  #1134
jayyyw's Avatar
Originally Posted by 98_WS6_M6
I have a feeling Tony is going to have a few mid 9 second passes NA floating around soon. I'll be waiting to see all the other builders cars catch up.
Highly doubt that. His packages have been out a few years and there have been no track numbers. Takes a hell of a driver to run a 9sec pass in a stick vette, let alone a mid 9 second pass. 90% of the HCI vettes have the power to run a 9sec pass but lack the driver's skill to get it to leave well enough. Myself included. Best I ever did was a 10.2 @ 142.5 with a 1.66 60ft.
I've made as much power as a Mamo top end package (on a SBE LS7) with nothing but off the shelf parts. The cam I used was even a blower cam, originally.
Old Feb 11, 2020 | 12:21 PM
  #1135
Smokey B's Avatar
Brother brother brother ...$6200 for a TFS casting above all things.
Old Feb 11, 2020 | 12:23 PM
  #1136
Darth_V8r's Avatar
Moderator
Not even close, man. $6200 was the BES price for a set of heads the way I want them set up... Just the heads, nothing else.
Old Feb 11, 2020 | 12:25 PM
  #1137
jayyyw's Avatar
750hp is a stretch, I've never seen that much out of a stock intake manifold. 61Xwhp is the most I've ever seen.
Old Feb 11, 2020 | 12:26 PM
  #1138
98_WS6_M6's Avatar
Cam - $450
Damn. Tony is even cheaper than I thought. Especially for a top of the line setup that no one seems to match.
Even both my tuners and one holds the LDR record said Mamo's stuff is pretty awesome in how it performs NA and neither of them frequent LS1tech YB or any other forums they just see results first hand.
Old Feb 11, 2020 | 12:27 PM
  #1139
Smokey B's Avatar
Video was 630 if I'm not mistaking and factory intake. John B made 620+ Factory intake..again nothing new.
Old Feb 11, 2020 | 12:35 PM
  #1140
Darth_V8r's Avatar
Moderator
Not saying it isn't badass what he did. But how is this any different than any other vendor for doing badass heads and an intake that chokes it back? And probably a hell of a lot more cam...
