Projekt Lazarus - Numbers Posted!!
Old May 2, 2022 | 01:10 PM
  #1461
Darth_V8r's Avatar
Moderator
PSA: reassembly goes significantly faster when you have parts vs not having parts...
Old May 2, 2022 | 01:26 PM
  #1462
grinder11's Avatar
Really nice job, Darth!!! Especially the ET. Quite a few cars out there that can run 130-134mph trap speeds, but damn few running 134mph in just over 10 seconds!!! You are SO close to the 9s......Great job!!!
Old May 2, 2022 | 01:49 PM
  #1463
Corona's Avatar
He's got the power, its the weight and being a DD is the best part.
true 9 sec n/a DD.
Old May 2, 2022 | 04:01 PM
  #1464
Darth_V8r's Avatar
Moderator
Thumbs down
true 9 sec n/a DD.
Thanks guys! That's the goal of this thing. DD 9 sec NA car. Even if it's 9.99x lol. I think If i can manage the launch better I should be good.
I'm actually home this week, so I'm hoping to get it driving before my next trip.
Old May 2, 2022 | 05:42 PM
  #1465
Bspeck82's Avatar
You got more in the 60. Just takes track time to find it.
Old May 6, 2022 | 08:33 AM
  #1466
AINT SKEERED's Avatar
Waiting for results, how the magnum shifts vs normal t56
Old May 6, 2022 | 10:23 AM
  #1467
Darth_V8r's Avatar
Moderator
Hoping to let everyone know soon. Exhaust is on, and all the crossmembers are in place. Driveline angles are all set . I need to address some exhaust leaks so I don't get stupid rich on fuel trims. I'm just not making any promises on timing, just because I cannot express how much I REALLY do not want to take this thing back out of service.
Old May 6, 2022 | 03:07 PM
  #1468
Corona's Avatar
Take your time and do it right so you can enjoy the Hp and not have 2 .....
Old May 8, 2022 | 08:10 AM
  #1469
cino's Avatar
Yes. I have a T56 magnum. It already arrived.
What output shaft comes with Magnum F?
Asking to figure if it requires different driveshaft yoke.
Old May 8, 2022 | 09:48 AM
  #1470
Darth_V8r's Avatar
Moderator
31 spline vs 28. I grabbed the sonnax yoke. It is 3/8 shorter vs the strange. Also, if your current yoke is a 1310, the new one will be a 1350. You need to figure that in as well.
If your rear LCA are adjustable you can sometimes adjust around the added length.
Old May 8, 2022 | 03:06 PM
  #1471
cino's Avatar
Noted.
Thank you Darth.
Old May 9, 2022 | 07:40 PM
  #1472
Darth_V8r's Avatar
Moderator
This happened!
I wasn't able to get a good rev clip, but I can sit in the cabin and it finally revs out like a banshee.
File Type: mov
Old May 12, 2022 | 01:28 PM
  #1473
Darth_V8r's Avatar
Moderator
More progress. I was able to get the OE dash working effective today. The vids are over here....
https://ls1tech.com/forums/pcm-diagn...k-harness.html
Post 78
Old May 21, 2022 | 07:09 PM
  #1474
Darth_V8r's Avatar
Moderator
Drove her around the block!! Some bugs to work out but she lives!!
Old May 21, 2022 | 07:46 PM
  #1475
01CamaroSSTx's Avatar
Post 78
Hell yeah... Like that throttle response.
Old May 31, 2022 | 07:14 AM
  #1476
Darth_V8r's Avatar
Moderator
Took her out for some exercise. My God, she's powerful. it may be that i's been a while since i have felt that kind of acceleration, but this is another level for me.
Tuning on the Holley is very different. You control the same stuff, but you do it differently. You have to train your brain to understand what is what. Fueling in my opinion is easier. You tell it what AFR you want in various places on the VE map, and it will trim to that AFR. Vs the stock computer that trims to stoich with the narrow bands and then uses multipliers. So, I idle at 16:1, go into deep deceleration at 17:1, cruise at 14.7, and full power gives 12.7. It's quite nice. Plus the factory computer, you cannot really see your fuel trims outside the log. in the holley, you can watch the log and tune at the same time. So you can see the learn values, and they're very straightforward. I did learn that i can command 18:1 idle, and the car will still run. But hwat happens is, the idle becomes very sensitive to learning. at 16:1, it is very stable. You can see it in the learn values. The trending side of the holley system is really much better than HPtuners. All the PIDs are always available and trended. you just activate and deactivate the ones you want to see. It's more like the IBA fast data acquisition software we use at work.
Timing is harder. I think I prefer the OE g/cyl load table vs the map sensor table. Especially since on the bigger cam, the entire bottom half of the VE table is irrelevant. My wife's tablet badly overheated while I was tuning, so I had to stop. But to say this, I was able to take a six mile drive, including some main road time, accelerate very hard, and not stall. Cruising was probably the worst. Just need to figure out what the cruising cells are in the timing table and push them to 33-36.
In other news, got the clutch bled down, and the transmission shifts so much better now. No issues with braking, lights, etc. Gauges are all in working order.
She's not track-ready yet, but I'm past the bullshit at least.
Old May 31, 2022 | 10:16 AM
  #1477
Gotta feel great to finally have it all (or mostly.... lol) sorted out!
Old May 31, 2022 | 10:30 AM
  #1478
HioSSilver's Avatar
Holley ftw
Old May 31, 2022 | 10:55 AM
  #1479
spanks13's Avatar
Big cam big throttle body is funny with the Holley. Like I paid for the whole table, I want to use it lol. Wish it were possible to increase the resolution of the table in the useable areas instead
Old May 31, 2022 | 11:22 AM
  #1480
QwkTrip's Avatar
Having two timing tables similar to GM has helped my low speed drivability a ton. I treat the base timing table like the GM high octane table. And then added a custom 2D table to modify spark timing at very low throttle conditions (pull timing at 0% TPS in my case, which also helps engine coast down to idle).
My low & no throttle conditions were basically overlapping below 2000 rpm so it was impossible to make both happy and my engine was bucking. Being able to command different timing based on TPS has helped a lot.
Got the idea from a guy on the Holley forums by the name of quarterbooty
