LSX 454 freshen up
#683
Ok , i put new front o2 sensors in , new plugs, checked spark, still running rough up until 300rpm.
Its in closed loop , reading 02s which are different .. Bank 1 shows .700mv bank 2 is 200mv at idle
Stft bank 1 -22% bank 2 50%
Tightened intake manifold, checked for exhaust leaks
Dont know whats goin on
#686
Id start switchn parts from bank to bank one at a time and see if the problem follows. Could also do a smoke test n see if you have any vacuum leaks. Do all the cheap inexpensive stuff first before you start buying parts
#687
im thinking its electrical, over 3000rpm there isnt a problem.... Ill go over everything again . The engine harness is dodgy , the car goes to sydney to have it all sorted in may
#689
i do have data logs, i pulled positive battery cable for 15mins to reset ecm and both banks are now in sync
the o2s are staying high 800-900 mv, stft gets up to -21% but with bit off throttle comes down, injectors pw are the same now.... somethings taking spark out at idle, sits on 5 degrees a lot which isnt rite.... lookin at fuel pressure reg it looks steady at 58psi, but i dont know if the fuel pumps are compatible with e85...
im just going to take to my tuner, to busy building my house
#690
It is idling rich, so it is idling fast. It cannot cut enough air to idle down do it is cutting spark. If you are speed density, multiply your 0-1200 columns by 0.8. If maf, multiply your idle cells by 0.8 on the maf curve.
#691
I had a few hours to go over everything again. I had no codes until today , would hv saved so much time if the code came up when it started playin up.. P0118 coolant temp sensor... bought a new one and now all good except stft showing rich...
a little bit of street tuning over the next few days and it’ll be 100%
Darth I’m speed density so I multiplied by .9 and upped spark by 4 degrees, then dropped idle adaptive a few degrees 300rpm and up... smoothed it up a lot , I’ll play with it a little more and see if can improve further
#692
The following users liked this post:
rkupon1 (03-03-2021)
#693
Is your new coolant sensor reading different values? If it reads colder you will be rich. I just bought replacement ones and it was off by about 20 degrees. Different part number on accident but no one talks about the difference.
Compare your temp to your IAT sensor when everything is cold.
#694
Did some more logging this morning , found the map reading between 60 and 100kpa.. replaced map then put old tune in it, now it’s 100%
found out the map, ist, coolant and oil pressure sensors run off the same 5v so if one goes it can wreck the others
water temps are all in line Spanks
The following 2 users liked this post by Mickyinks:
rkupon1 (03-03-2021), tblentrprz (03-03-2021)
#695
Is it hard to replace valve springs???
dont know where the top bit of spring is, but fair chance it’s in the engine lol
neef a pair of rockers also,
i had heard a small tap for a few days, just thought was time to do lash
#696
It is fairly easy to do it with the head on you just need the right valve tools - I use the LSM stuff. That being said you will need to do a compression test as you may have dinged the valve into the piston due to loss of valve control (loss of compression will show a bent valve). The good thing is if you got like Weisco / aftermarket pistons the valve relief is enormous and deep I have a 246/258 660 cam and I think I have .100 more clearance than the .080 and .100 you want to have in first place. I would also look at the retainers they look a little small for holding in that big spring - maybe its normal. I had something similar found it by the laser heat gun at idle (odd side bank number 7) 450, 450, 435, 150 oops.
#697
You just need an air compressor hose that winds into spark plug hole, see link below. Then you hook up air compressor working at 100psi or more and it keeps the valves up in the head. Watch out when you hook up the air to that cylinder as it'll turn the engine over to push that piston down in the cylinder, so don't have anything around the front of engine when you do it. Then get a valve spring compressor tool and compress spring, remove collets and retainer etc. Fairly easy. Also get a telescopic magnet to grab the retainer collets when you compress the spring, so one doesn't accidentally go flying down a pushrod hole.
https://www.ebay.com.au/itm/CYLINDER...frcectupt=true
rkupon1 (04-13-2021)
#700
I’ve been busy building new house and forgot I was going to replace springs after 18 months. I’ve done nearly 30,000miles since full rebuild so I’ve gotten good spring life for solid roller
G Atsma (04-13-2021)
