LSX 454 freshen up
Old Jul 4, 2021 | 07:35 PM
  #721
01CamaroSSTx's Avatar
Originally Posted by Mickyinks
What cam ?
ive been running 1209x ,
LME heads purchased in 2018 and I'm still on a hydraulic roller with the T&D pedestal mounts but the 01 cam is 243/251, @.050 .661/.633 115+5 on 1.8's.
Old Jul 4, 2021 | 11:11 PM
  #722
Mickyinks's Avatar
I just weighed one of my yella terra adjustable rocker arms, Damn your T&Ds are 75odd gram heavier.... Thats a LOT....
No sign of valve float?
Old Jul 5, 2021 | 07:35 AM
  #723
Haven't noticed any signs but then again I'm not spinning to 6-7k all the time either. I've been told that overall weight has nothing to do with it but more of what the weight is over the valve but that time to replace springs is here and I'm wondering if I should go with a stiffer set.
Old Jul 5, 2021 | 08:07 AM
  #724
Stock rockers with Straub bushings.
Harland Sharpe's
T&D Stainless Steel ones. The motor does seems to respond better with the stock rockers with the slightly longer 3/8 purhrod though.
Old Jul 5, 2021 | 11:57 AM
  #725
Jimbo1367's Avatar
What’s that white powder on the scale?
lol
Old Jul 5, 2021 | 12:26 PM
  #726
spanks13's Avatar
My TD rockers are 173g and 161g.
Old Jul 5, 2021 | 12:51 PM
  #727
IDK....Maybe we should get it tested. Not sure there's enough there for me to make a positive identification but I can see the implications mounting. BTW what do you do for a living Jim? Are you buy chance a peace officer because that's the feeling I'm getting here.
The high cost of living is nothing like the cost of living high. JJ
Old Jul 5, 2021 | 12:53 PM
  #728
I did have a set and like those they were for the LS7 factory heads. These one's are for the Brodix BR7's
Old Jul 5, 2021 | 01:16 PM
  #729
spanks13's Avatar
Makes sense! Yeah these are for factory LS7 (except you need to grind on all the pedestals to make them fit...)
Old Jul 5, 2021 | 01:27 PM
  #730
And are scales are also in agreement!
Old Jul 5, 2021 | 03:46 PM
  #731
Mickyinks's Avatar
this is a yt exhaust, add a few grams due to damage from when spring broke
this is over the nose, scale bounces around by 5g goes as high as 19g
Old Jul 5, 2021 | 03:52 PM
  #732
Mickyinks's Avatar
Looking at the pics there not apples to apples , all have shafts where the yt only has trunnions
Old Jul 5, 2021 | 04:03 PM
  #733
Mickyinks's Avatar
If I had to guess I’d say to be somewhere close you’d add 50g for shaft to yt weight . The yt shaft for intake n exhaust weighs 150g
Be good to know the t&d trunnion weight
If that’s the case the T&d and yt would be very close to same weight...
Old Jul 5, 2021 | 05:13 PM
  #734
Overall weight means nothing from a performance perspective. It’s the nose weight that you have to look at when comparing rocker mass that the spring will see. Here’s a couple pics…YT adjustable vs. Oem LS7 rocker nose weight comparisons. I left the needle bearings in the YT’s so that added a few grams, for the record…
Old Jul 5, 2021 | 05:20 PM
  #735
Corona's Avatar
To Real People .......
If We've got this Much Money 💰 Invested
Y
In the Hell are We talking BS rockers?
Jesel or Crower ...T&D shaft mounted....
​​​​​​​Old conversation for a New BS generation sold on BS?
Old Jul 5, 2021 | 05:22 PM
  #736
Corona's Avatar
What Rocker arms Win Championship's?
Common sense with $
Steel Doesn't Move and what ever Extra weight used with the Rocker Doesn't Equate to weight nor Mass ..with the System ....
​​​​​Chris U.
Old Jul 5, 2021 | 06:20 PM
  #737
[QUOTE=Che70velle;20364172]Overall weight means nothing from a performance perspective. It’s the nose weight that you have to look at when comparing rocker mass that the spring will see.
Stocker rocker wins again!
Old Jul 5, 2021 | 06:42 PM
  #738
[QUOTE=01CamaroSSTx;20364190]
Hard to beat, no doubt. Lightweight and strong.
Old Jul 5, 2021 | 07:02 PM
  #739
Corona's Avatar
Lil ***** Small cam and it's lift .....
Stiffness ....Lose Weight in Valves, springs Retainers, etc....
It's Called Deflection.... WORDS NOT USED HERE AND WHAT HELPS.
Old Jul 5, 2021 | 07:12 PM
  #740
Corona's Avatar
Only thing to Help a Stud mount is a Girdle....
But Tony Mamo did this in a Test.
Stud vs Shaft mounted with the 383.... Don't believe he or they had a Girdle @ the time.
Still Don't ....
Custom 1 of 1...
Eric Roycroft Taught.
