LSX 454 freshen up
Old 08-05-2020, 08:06 AM
  #521
AINT SKEERED's Avatar
Originally Posted by Mickyinks
Im on the rite track then, thanx mate. Ive set to .005, split the difference.
The head bolts that you have to do up thru the valley windows suck big time.. Having to lift the lifters up to get at the bolts, was on the last one and didnt realise id pulled lifter out of its hole and the F ing nut fell down it... I had made sure the lifter wasnt totally out its hole on all the others. Thought i was doomed, then put a magnet down the hole and out it came with the nut...
Id have it up n running tomorrow but no point in it really. Covid lock down starts tonight, 6 weeks and can only leave the house for food, medical needs, the essentials. Have already been in semi lockdown for 3 weeks. Basically only had covid cases in quarantine under guard, but the guards were bangin the ladies ,sharin smokes , and now we are up to 700 cases a day...
so is it a 99.6% survival rate there as it is here in USA?
Old 08-05-2020, 08:27 AM
  #522
bortous's Avatar
Its the same as everywhere else.
It's just a ******* scam.
There are 240 deaths in a population of 25 million and it's a pandemic is it?
It's so deadly that you need to be tested to even know you have it?
Why would they send you home for 14 days quarantine to recover? Shouldn't you be in an isolated hospital wing if the risk is so great?
All fear ****.
It's really pissing me off.
​​​​​Rant over till further notice.
The following 2 users liked this post by bortous:
G Atsma (08-05-2020), Launch (08-05-2020)
Old 08-05-2020, 08:55 AM
  #523
ramairws6's Avatar
All fear ****.
Wow....you guys get it over there too lol! What a joke....
The following 2 users liked this post by ramairws6:
Old 08-05-2020, 09:57 AM
  #524
Received 3,216 Likes on 2,512 Posts
Same effing BS the world over... major political football.
The following users liked this post:
Launch (08-05-2020)
Old 08-05-2020, 10:56 AM
  #525
ramairws6's Avatar
Originally Posted by g atsma
same effing bs the world over... Major political football.
bingo!
Old 08-05-2020, 07:06 PM
  #526
rkupon1's Avatar
Its like being the kid born on leap year. Our elections are once every 4 years, so at least we ll be happy and logical for 3 of em...Merica!
The following 2 users liked this post by rkupon1:
AINT SKEERED (08-05-2020), Che70velle (08-05-2020)
Old 08-06-2020, 06:40 AM
  #527
Mickyinks's Avatar
The government can lock me down whenever they want, ive scored about 15k in government handouts so lock me down some more lol
Old 08-06-2020, 06:44 AM
  #528
bortous's Avatar
Buy me some pushrods.
G Atsma (08-06-2020)
Old 08-06-2020, 10:11 AM
  #529
Are those legal tender yet? LOL
Old 08-07-2020, 03:50 AM
  #530
Mickyinks's Avatar
I have a question about spark plugs.
I think i know the answer but are sparks plugs the same for LS1 Ls2 Ls3 Ls7?
I usually use NGK tr6's... I dont think i need a Tr7... Thoughts?
Should have it fired up by tuesday...
Old 08-07-2020, 03:56 AM
  #531
bortous's Avatar
Are you on e85 Mick?
Old 08-07-2020, 05:02 AM
  #532
Mickyinks's Avatar
I have a flex fuel sensor, will run it up on both 98 and e85, see what difference it makes. Ill probably only run e85 on track days
Old 08-07-2020, 06:32 AM
  #533
Received 3,650 Likes on 2,230 Posts
Mick with your heads and compression I would have spec’ed a 7 plug, but if the 6’s (a step hotter than the 7) have been Reading ok, then run them. Could be the fuel difference between us.
Old 08-07-2020, 08:29 PM
  #534
Mickyinks's Avatar
I was thinking about trying a 7. I have upped comp from 11.6 to 12.3 and with you saying a 7 i think its worth trying .
does e85 come into play in regards to plugs?
Old 08-07-2020, 08:36 PM
  #535
E85 burns cleaner than gas, so there isn't as much need to keep the plug hot. A switch to E85 can sometimes mean running a bit leaner/hotter, so a cooler plug can be tolerated. So there is a reasonable train of thought to think about heat range of plugs and e85. I’ve never ran e85, so I can’t speak from experience here, only theory.
Old 08-07-2020, 08:56 PM
  #536
Mickyinks's Avatar
Ill try the 7s and do the usual after 1st start. Get it up to temp, switch off ,check lash, let it cool, check oils, check plugs, if all good go do some street tuning.
1st start will be end of next week, i have to get oils, plugs delivered. Im looking forward to seeing the difference with the new cam. I was at 667rwhp and my goal has been 674 rwhp.
Ill be dissapointed if i dont hit it.
Old 08-08-2020, 10:51 AM
  #537
ramairws6's Avatar
I run the non projected 7's on 13:1 compression E85 deal and its been working good. Switch to the 9's on spray. https://www.ngk.com/product.aspx?zpid=9538
AINT SKEERED (08-08-2020)
Old 08-09-2020, 12:42 AM
  #538
jayyyw's Avatar
I saw a 4hp loss on the dyno swapping from 6s to 7s. I ran 7s and there was no noticeable difference over the 6s. I would use the 7s just to be on the safe side.
Old 08-12-2020, 08:23 AM
  #539
bortous's Avatar
Start that bitch up!
Old 08-12-2020, 10:57 PM
  #540
Mickyinks's Avatar
Turned the key and fired up straight away with good oil pressure. Doesnt sound any where near as grumpy. old cam 259/265 new 255/269
Only prob is i need to get new exhaust manifold gaskets
Quick Reply: LSX 454 freshen up
