Top end choice 6.2
New member here. I have a 6.2 L92 short block that has no heads, cam or Intake. I want a nice running motor for my Chevelle and I’m not to sure where to go with it. I was thinking of going with 862 5.3 heads, putting valve springs on it to match the summit 8707 cam (226/238 .600/.600 lift 113LSA). Stock Truck intake. It’ll be bolted to a manual trans with 3.73 gears. How does this sound to you guys? Decent build?
Do that and your needing LS3/L92 cylinder heads though!
I'm thinking 862's are way to small for that bore. I would be looking for some 243's if it where me and I wanted to keep the truck intake.
I’ve thought about that but around here I can get the 5.3 heads for so dirt cheap I thought I’d try them out. Maybe I’ll drive it for awhile then upgrade to some trick flows or something, maybe even going to rectangular port. I’d just like to build a cheap fun motor.
The 6.2 is a 4.065 bore and would really benefit from the LS3/L92 heads. The 862's went on the 4.8's and 5.3's which only had a 3.780 bore and that's hurting your horsepower no doubt if you run them.
The following users liked this post:
garygnu (11-14-2019)
what cam would you guys recommend with the LS3 heads? This car is going to be a DD so I’m looking for great drivability but good power.
With LS3 heads/intake, long-tubes headers and a 2 1/2" exhaust....a very tamed and easily drivable 460hp/425tq (conservative SWAG) to the wheels would be on tap. Mill the heads to yield about 11.3:1 compression with a .040" head gasket and you'd be real close to 500hp to the wheels.
KW
The following 2 users liked this post by KW Baraka:
G Atsma (11-01-2019), JF74chevelle (11-01-2019)
The following 3 users liked this post by JakeFusion:
Okay guys. I really appreciate all the advice. Exactly why I asked this question. I’ll definitely be sticking around this forum, lots of knowledge here! Thank you.
They'll work, but are not an upgrade from the LS3 heads; if they are like LS9 heads, they actually flow a bit less due to small "wing" airflow vanes in the ports that help supercharged air flow. Other than that they are identical.
The LSA heads also have a stupid heavy intake valve in them and the swirl casting in the port is there I believe for MPG/efficiency and not flow..... I would get L92 heads and put in a lighter weight intake valve.... or just sack up and buy some LS3 heads that already have the lighter valve. Gotta love a factory head that flows 330cfm
https://www.lsenginediy.com/ultimate...r-heads-guide/
