Btr stage 3 vs. Stage 4
I had a BTR 4 in my car (not a GTO). I loved the cam. It came on around 3500 RPM and pulled to 7k. I have 3.70 rear gears and a T56 from a 2006 GTO.
Really if you're not willing to rev to 7000 then get a smaller cam.
Generally, no one gets exactly what they want the first time around UNLESS they have a frame-of-reference. That is; they know someone with a setup that's close to or exactly what they want.
That much having be said, it's best to err on the side of caution....and go smaller (versus larger) with the cam.
KW
KW
Regardless of what cam you go with, you need supporting mods for it to work efficiently. Compression, gears, stall, etc.
Yeah a stage 4 cam may make 10hp at peak, but under the curve power is **** and it's a PITA to drive on the street.
Neither engine likes to be much below 20 mph. Once on the move it drives fine. I just have to drive more aggressive off the line than the Average Joe to keep the engine happy.
And therein lies the problem. You see, there are a lot of Average Joe's on the road. And what's even worse is Slow Toyota Joe. My cam and clutch cause me to move at a different cadence than other cars in traffic. It's not a huge deal as long as I have a couple car lengths between us. But if it's a slow moving line with people creeping on their brakes.... then it's hell on my clutch.
So I'd say if you do a lot of rural driving then you'll not mind a Stage 4 cam. If you do a lot of city driving then it can become a real PIA.
You hit on something too. A really hopped up manual really needs to just launch in order to drive decent. And nobody else on the road knows which pedal makes the car go.
