Are 390ci setups still common?
I remember back when AES was pushing the 390ci combo hard for force induction setups. The logic behind it as many of you know was that a 4" stroke was hard on the skirts since the bores of the gen 3&4 6.0L iron block are short and pistons at BDC come further out of the block when stroking to a 4".
Hence AES promoting the 390ci and using a shorter 3.825" callies crank with 4.030 bore on a gen 4 iron block. Still not as easy on the skirts as a 3.662 stroke, but not as hard on the skirts as a 4" stroke.
Since piston design has improved over the years, it seems that the use of 4" strokes in applications where the car is a weekend warrior that sees the track 4-5 times a year are far more common these days over the use of a 3.825 or 3.9 crank with little concern of skirt wear simply due to less use on the motor. Seems like 390ci is no longer a thing on these stroked iron setups and many just go with the 4" stroke / 4.030 combo and make it a 408 if using a gen 3/4 block, or go 427+ if using the SHP dart ls next block.
I was considering a L96 block and just leaving the rotating assembly stock and just seeing how long I can make it last on boost pushing the 1100-1200hp limit but running it much lower than that on the street (vs upgrading the rotating assembly). Then I got to thinking about skirt wear and if I should go to a 4" stroke or a 3.9". Then I got to thinking about the hp limitations of the block itself and by the time the machine work is done on an L96 block + cost of the rotating assembly + putting on a different set of heads to tie it all together, you have to step back and take a look at what that costs vs doing the SHP dart setup and addressing the concern of the block being the weak point. I'm not looking to make over 1200hp and when I do push it to around there, it's only going to be at the track. So my options are to keep it around 1000hp and be somewhat durable or spend the $$ and do it right. There's just something about going the cheap way first and seeing how long it will last vs going the other route. I'm still undecided.
In my opinion if your doing Forced Induction, skip the stroker crank. Just increase the boost a slightly to make up for the loss of cubic inches. Many times 5.3's and even 4.8's can be pushed to 1,500 hp with forced induction.
The 4 inch stroker cranks work great in NA applications when the correct taper piston is used.
The following 3 users liked this post by 99 Black Bird T/A:
Probably just a few pounds of boost to offset less cubes due to not having the stroker crank. Maybe 2 pounds of extra boost or even 3 pounds of extra boost of off set ~30 to 40 less cubes?
A good set of ported heads would probably help offset the heat issue of 30 or so less cubes and slightly more boost.
One of the true guru's who used to post frequently implied the 4 inch crank really wasn't worth it on most FI builds.
Agree there are always trade off with all of it.
My opinion is if you are boosting, building a stroker is a complete waste. If you want to go faster, put the $$$ in the heads/valvetrain/FI side. Making the motor physically bigger cuts the lifespan and makes for a whole new world of problems. Making the induction more efficient and it will make power w/ less stress/boost.
I feel 5.7stroker should pose the following question to everyone:
Should preference lean towards a shorter stroke 390" engine built with an aftermarket block and rotating assembly...
-or-
Build a 408", 4.000" stroke engine with an aftermarket block and rotating assembly?
-or-
-or-
-or-
In the end, it all depends on the end user's application and duty cycle. If they are building a street car with the intent of long life, then a 3.900-inch crankshaft is probably going to suit them better and provide them with the durability they are looking for," sums up DiBlasi. "For all-out drag racers who refresh their engines often, they are looking for max power and a longer stroke will be the obvious choice."
The article mentions a 3.900" crank and the question takes it another step further with the 3.825" crank used in the 390ci.
https://www.hotrod.com/articles/choo...-engine-build/
Yes with the stipulation that both combos will see boost. I came across this 2017 article which states:
But, I've decided I don't hate money and am more than happy with a 900-1000 hp car.
Lots of engine builders putting together 4" stroke motors for forced induction applications with the correct piston taper for a stock block. Look at LME for example.
K1 still makes a 3.9' stroke crank. Also, the brand new 6.6 GM engine has a 3.86" stroke, forged CCW crank that is already being exploited for stock LS block use.
Once you start down the DART block road, everything naturally tends to get "next leveled". Rods, pistons, crank, heads, etc...
I've debated the exact same options in my car.
Yes there's definitely an increase in cost the moment you start going past 1000 hp. I think this is why many guys just stick with the factory blocks and modify those along with good weight reduction to hit their ET goals rather than going with the aftermarket block route. The costs go up quickly when you start to go past 1000 hp while still wanting reliability.
1000hp in just about anything is fast. With that, I'll take the torque curve offered by the bigger displacement/larger bore (4" +) engine at a lower RPM.
The following 2 users liked this post by ddnspider:
Tuskyz28 (04-05-2020), vorteciroc (04-05-2020)
So in a nutshell:
If going aftermarket block, a 4" stroke is a fine choice. You'll make excellent power boosted with a block that is not being pushed to it's limits at 1000 fwhp, and can certainly go over that amount of hp without issue providing that the block is properly built for it.
If staying with a stock iron 6.0L as the starting point, mill it 4.030 and use a 3.662 crank because even with a bigger crank making more displacement and more power, your limited by the block itself and are pushing the block to it's limits at around 1000 fwhp. Upgrade the internals if planning to be around the 1000 fwhp limit if you want the block to last longer. You have the option of going with a bigger crank like a 4" and it will require less boost to hit the 1000 fwhp limit, but you need to account for piston design as well. This will result in less turbo lag on the street at reduced boost level due to the larger displacement.
