Delayed oil pressure with my ls2 6.0 swap
Hi,new to the site,i did a ls2 swap in my c10,worked out great and is running great but i have about a 5 to 10 second delay on oil pressure on cold start,any advice would be great
Check with a mechanical gauge. Maybe a bad sender. It does OK after warm?
How many miles/condition on engine?
What oil are you running?
Fresh rebuild 05 6.0 vette engine,5w 30 oil,after the delay the oil pressure quickly goes to around 40 psi,it seems like bleed back as i have to leave it sit a while for it to do it again
So 40 psi cold, what’s your pressure at idle after warmup?
How many miles on oil/filter?
The oil filters on these LS engines are small, and clog easily. Any greases or pastes that “might” have been used when assembling the engine, along with debris from cylinder walls or what have you, end up in the filter. I’d try another filter. Don’t change the oil, just the filter. Take you what, 5 minutes? Worth a try.
