Best cam fo a 6.0 with Ls3 heads?
Hey guys, looking for some more info, so I have a 6.0 bored 40 over, stock crank, LS3 heads, stock for now, will be porting, looking for the best cam possible for street use, going in a 93 s10, with 4l80, and a 9" Ford with 3.89 gears, going efi Holly or fietech, not sure yet, what are your thoughts
That's the pistons
That's the pistons
"I MAID THEESE"
That's the pistons
That's the pistons
Id go wirh a stage 2 ls3 cam from Summit, tsp, btr etc . A medium sized ls3 cam would work great
The following users liked this post:
camarozz383 (08-09-2020)
Throw a LS2/6 cam in there and be done with it. Lol.
I am only half kidding... the rest of the combination looks like boost is in the future, anyways.
My build that I'm working on is similar. My shortblock isn't bored, but I am putting together a stock LQ9 bottom with stock LS3 topend. I had my cam specced by Pat G. It's 227/236 which is right in the same ballpark of the stage 2 cams that Mavn was talking about. The stall you plan on running is going to play a role in the selection. I'm going with a 3600 in my C5.
Holley will do a better job than FiTech. A more comprehensive setup.
The following 3 users liked this post by G Atsma:
Depends on what youre trying to do.
3.90 gear and N/A you wont use all of third gear in 1/4 mile. How much stall are you willing to run?
heres 2 summit cams im checking out for my combo (gen 4 6.0, t56, 4.11, 350lb) leaning towards the 226 for a street car, actually. These are a bit milder than what youve been looking at.
SUM 8708 231/242 113+3, .600/.600
SUM 8707 226/238 113+3, .600/.600
all depends where you want your powerband to be and how much valvetrain maintenance you want to do.
