No oil pressure
Somebody posted a scan of Melling's instruction sheet. Actually there are a couple of posts of a couple of scans of a couple of different instructions. The definitive one shows 3 configurations of the pickup tube; the ones that will send you into the weeds if you're not careful only have 2.
Oil pumps all have the same bore for the pickup. There are 3 pickup styles: straight, "tapered" or "flared" depending on which direction you're going in your description, and "stepped". The stepped one is obvious; the outer, larger portion is something like .87" OD, and the inner, smaller section (where the O-ring goes) is something like .84". The "tapered" type has the same quantitative difference; the end of the tube is .87" and it necks down to .84" right past the bead that seats against the pump casting. The straight one is just exactly that: .87" all the way.
The stepped and tapered ones both take the thick O-ring. The straight one takes the thin one. DO NOT try to go by color!!! There are / have been MULTIPLE colors of both sizes, leading to enormous confusion. The important characteristic is SIZE, NOT color. The correct O-ring should be a nice tight fit, with a drop of oil or light smear of grease; it should require a little effort to put in, but once started, should slide in easily. It should NOT just drop in: if it does, you have the thin one where it should be thick. It should NOT stay outside of the pump bore and refuse to go in: if it does this, you have the thick one on it but need the thin one.
I HIGHLY recommend this little doodad right here. Billet BarBell (saccitycorvette.com) Note that the page is improperly named. You may find, with some pickups, that you'll have to grind a flat on one side, because the flange of it is too big to sit next to the tube. Not a real big deal. The other side has a bolt from the factory. I've never seen any nuts associated with it.
The barbell won't cause low oil pressure at the point you describe measuring. It will only allow dirty oil to bypass the filter. One thing that will though, is the oil gallery plug at the front of the motor, right next to the pump. The cam retainer plate is another potential culprit.
did you remove the oil pump? Did you properly align the new pump with shims or alignment tool (I.e. SaccityVetres s tool) ????
I hope you didn’t just bolt it on like a typical SBC or BBC.
Sadly, in this case, the engine is in my old truck that has a Fatman frontend which has a solid crossmember.
I have spent some considerable thought on the engine since your post regarding the front oil gallery plug. I clearly remember installing a new rear dumbbell plug because I read "horror stories" about rebuilders forgetting to install it. I do not recall installing a front gallery plug. This means it was so routine that it did not create a memory or, it did not happen. I am hoping for the second option. I don't recall having any issues with the oil pickup o-ring and I don't believe that is the problem; however, if the front plug is not the issue, the o-ring will be my prime suspect.
On another note; I bought a cheap $15 12v oil/fuel pump off ebay. I removed the screw in galley plug and plumbed the pump outlet into that galley hole. After about 15 seconds, my gauge showed 50 psi of oil pressure. I let it run until the pump got seriously hot and oil was coming out of the pushrods. I figured by that time, it was well primed.
OP, sounds like the plug or barb. Sounds like you may know the galley plug was pulled at the shop.
